Old 10-23-2017, 06:42 PM   #1
hpde_addict
Drives: '18 Camaro V6 1LE
Any tips for replacing ignition coil B (driver front)
I'm consistently getting the check engine light for ignition coil B. Will be replacing it tomorrow. Were you able to reach it without lifting the car? Any components that I should unbolt and move out of the way? Any tools you would recommend? I have a 3/8 drive ratchet and torque wrench, but the fit looks really tight.
hpde_addict is offline   Reply With Quote
Old 10-23-2017, 07:58 PM   #2
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
The port injector cover is going to be a bitch to remove (to get space to see the coil packs) unless you disconnect the fuel lines (pull out pump fuse, messy). I managed to wiggle the cover towards the front of the car with the oil filter and engine oil screw cap removed - lots of to & fro and moving shit out of the way but at least I didn't have to get fuel everywhere.
You can get to the 10mm bolt holding the coil pack with a small ratchet (and hopefully not giant hands). See 3rd photo in this thread: http://www.ft86club.com/forums/showthread.php?t=88906
At least you don't have to get to the spark plugs - that's a whole shebang by itself.
enouf is offline   Reply With Quote
The Following User Says Thank You to enouf For This Useful Post:
hpde_addict (10-24-2017)
Old 10-24-2017, 12:57 AM   #3
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Bro, I removed all my ignition coils and wrapped them in gold tape. Trust me, so much easier lifting the motor. And you don’t need a torque wrench, just hand tighten and you’re good.
Dr. BRZ is offline   Reply With Quote
The Following User Says Thank You to Dr. BRZ For This Useful Post:
Old 10-26-2017, 09:59 PM   #4
hpde_addict
The 3rd photo makes it look easy lol. Do you think it's doable without removing the oil filter? I'm worried that the oil will flow everywhere (JR oil cooler). Going to try again tomorrow morning, wasn't able to finish before sunset.
Old 10-26-2017, 10:39 PM   #5
Icecreamtruk
Drives: Track preped NA FRS
That photo is of the passenger side, its a lot tigher on the side you need to work on, good luck
The Following User Says Thank You to Icecreamtruk For This Useful Post:
hpde_addict (10-27-2017)
Old 10-27-2017, 02:20 AM   #6
mkivsoopra
Little late, but you only need to remove the injector cover. We do this at the track between sessions all the time.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
Old 10-27-2017, 04:23 PM   #7
hpde_addict
Thanks for the tips, did it this morning. For clearance I removed oil fill cap, port injector box (the art of wiggling), strut tower bar, and unclipped fuel hose holder thingy.
The Following 2 Users Say Thank You to hpde_addict For This Useful Post:
Icecreamtruk (10-27-2017), mkivsoopra (10-27-2017)
Ignition coil questions hpde_addict Engine, Exhaust, Transmission 20 05-12-2017 10:34 PM
CEL P0351 Ignition Coil A Exrald Issues | Warranty | Recalls / TSB 16 03-23-2017 11:09 PM
Ignition Coil A CEL Whats that smell? Issues | Warranty | Recalls / TSB 12 10-10-2016 01:09 PM
WTB DRIVER SIDE FRONT BC COIL skavengers412 Want-To-Buy Requests 0 03-28-2016 01:41 PM
Ignition Coil C replacing - need assistance Synack Issues | Warranty | Recalls / TSB 8 09-09-2014 03:35 PM
