Old 09-13-2017, 04:42 PM   #1
azynneo
Will changing wheel width and offset affect alignment?
I've changed rims with the same dimensions just a lower offset and the passenger side seems to poke out quite a bit more, I thought only suspension mods affected alignment unless I'm wrong somewhere.
azynneo is offline   Reply With Quote
Old 09-13-2017, 04:49 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Lower offset = more poke, your alignment (caster, toe, camber) will stay the same.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
wparsons (09-14-2017)
Old 09-13-2017, 05:02 PM   #3
azynneo
but only one side is poking out more that's the problem, does that mean my alignment was fucked up to begin with? lol
Old 09-14-2017, 07:53 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Got a pic? Perhaps the offset or wheel width is different? Also check to make sure there aren't any wheel spacers on that side.
Current DD: M235i
Old 09-14-2017, 08:26 AM   #5
azynneo
Offsets the same, wheel width is staggered 9.5 and 10s in the rear both same offset. I don't run spacers. Probably an alignment issue..
Old 09-14-2017, 09:15 AM   #6
8RZ
The Gunshine State
8RZ's Avatar
Yeah that's odd, I guess the top of the wheel would poke out more if that side had extreme positive camber or vice versa if the bottom of the wheel is poking out more.
Current DD: M235i
Old 09-14-2017, 09:39 AM   #7
CatDaddysBBQ
Drives: '13 FR-S
just throwing this out there.
maybe your staggered setup got switched? Is it possible you have a front and a rear on the same axle?
CatDaddysBBQ is offline   Reply With Quote
The Following 2 Users Say Thank You to CatDaddysBBQ For This Useful Post:
Icecreamtruk (09-14-2017), wparsons (09-14-2017)
Old 09-14-2017, 03:22 PM   #8
azynneo
I checked already, this wasn't the case.
Old 09-15-2017, 01:46 PM   #9
CatDaddysBBQ
Drives: '13 FR-S
I assumed as much, just one of those "take out the obvious variables first" ideas.
Handling characteristics with a low offset and narrow wheel width surfwaxsmitty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 05-24-2017 08:04 AM
Will different offset affect the car? Magiclow Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-13-2015 02:57 PM
Will OEM camber bolt install affect alignment B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-23-2014 11:30 PM
Desired Wheel Size, Width, Offset - OPINIONS CSG David Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 05-21-2014 12:02 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
