Old 08-16-2017, 02:52 PM   #1
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
My experience after spinning a bearing
Short version, spun bearing, decided to go used while rebuilding....been a long 3 weeks without my car but she is finally back on the road. Thought I would share the experience so others may learn from my mistakes
For the full version, see attached PDF.
Keep in mind there are 2 things I had never done before, swapped a motor in an FRS or rebuilt any motor.....I have now, twice for the swap, and will be twice for the rebuild
All questions or comments welcomed!!! Enjoy the read
TEWwild is offline   Reply With Quote
The Following 20 Users Say Thank You to TEWwild For This Useful Post:
Capt Spaulding (08-16-2017), chaoskaze (08-16-2017), Extreme86 (09-05-2017), Guff (08-16-2017), Icecreamtruk (08-16-2017), imnotsureaboutbrz (08-16-2017), jasonojordan (08-16-2017), JoeC (08-16-2017), ls1ac (08-16-2017), Lynxis (08-18-2017), mazeroni (08-17-2017), microbionic (08-18-2017), ScoobsMcGee (08-18-2017), stevesnj (08-16-2017), Tcoat (08-16-2017), Teseo (08-16-2017), toeout (08-16-2017), Ultramaroon (08-17-2017), URACK (08-16-2017), Williampreza (08-16-2017)
Old 08-16-2017, 03:09 PM   #2
imnotsureaboutbrz
Drives: between cars...
Great write-up and documentation of your experience and thought process. Sucks it happened though.
imnotsureaboutbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to imnotsureaboutbrz For This Useful Post:
Tcoat (08-16-2017), TEWwild (08-16-2017)
Old 08-16-2017, 03:21 PM   #3
Very nicely done! Both the work and the write up.
Refreshing to have somebody break something, fix it and carry on with no whining, complaining or blame seeking.
Icecreamtruk (08-16-2017), imnotsureaboutbrz (08-16-2017), Lynxis (08-18-2017), stevesnj (08-16-2017), Teseo (08-16-2017), TEWwild (08-16-2017)
Old 08-16-2017, 03:30 PM   #4
stevesnj
stevesnj's Avatar
I have a feeling he's over 35
My 2016 Build thread
The Following 5 Users Say Thank You to stevesnj For This Useful Post:
fx1mark (08-18-2017), jasonojordan (08-16-2017), roddy (08-18-2017), Tcoat (08-16-2017), TEWwild (08-16-2017)
Old 08-16-2017, 03:37 PM   #5
Don't burst my bubble!
Old 08-16-2017, 03:51 PM   #6
OND
OND's Avatar
Drives: 2023 BRZ
Sucks to hear man, what the hell happened?
Kudos for taking on the motor swap/rebuild!
OND is offline   Reply With Quote
Old 08-16-2017, 04:12 PM   #7
dattran86
Driver
Drives: 2013 Whiteout FRS
3: If you can’t afford to pay, don’t play (too hard)
this is a really good advice lol.
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
The Following 2 Users Say Thank You to dattran86 For This Useful Post:
Old 08-16-2017, 04:17 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Great writeup, except for most people I would recommend a leakdown test instead of compression test as it helps to better diagnose source(s) of leaks in an engine, especially one that is out of a car.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Old 08-16-2017, 04:51 PM   #9
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Considering you've never been into an engine, your progress is nothing short of amazing. Congratulations and good wishes.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Old 08-16-2017, 05:36 PM   #10
TEWwild
TEWwild's Avatar
Yup, will be 48 in November....
The Following 3 Users Say Thank You to TEWwild For This Useful Post:
roddy (08-18-2017), stevesnj (08-16-2017), Tcoat (08-16-2017)
Old 08-16-2017, 05:38 PM   #11
TEWwild
TEWwild's Avatar
It's all in the attachment, as for the reason for the spun bearing, see lesson learned #1 at the end....
The Following User Says Thank You to TEWwild For This Useful Post:
Tcoat (08-16-2017)
Old 08-16-2017, 06:02 PM   #12
matchamochi
matchamochi's Avatar
Drives: swp brz
What caused the loss of oil? Just too many track sessions without checking/topping off?
matchamochi is offline   Reply With Quote
Old 08-16-2017, 06:54 PM   #13
TEWwild
TEWwild's Avatar
Hate to admit, but yeah, hadn't checked it in a while... Thought about it on the way but once I got there, just changed tires and hit the track. 4 laps in, noticed a loss of power then heard the dreaded rod knock. Wasn't sure of the source so took a cool down lap, 3/4 of the way around, stalled when downshifting......Had it pulled into the garage to cool down. Started once after cool down, heard the knock for sure and shut her down.....
The Following 2 Users Say Thank You to TEWwild For This Useful Post:
matchamochi (08-16-2017), Tcoat (08-16-2017)
Old 08-16-2017, 08:21 PM   #14
humfrz
Good job, young man ......
I like your lessons learned ......
Some day, you will be able to tell that story as a back-in-the-day story.
However, since you already showed pictures of your garage, you won't be able to tell folks that you did that engine rebuild, in a drafty barn, during the winter, in subfreezing temperatures, working on a dirt floor, using only a monkey wrench and a screwdriver, working at night and seeing only with a coal oil lantern.
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
stevesnj (08-16-2017), TEWwild (08-16-2017), Ultramaroon (08-17-2017)
AC compressor pulley not spinning when dis-engaged? Lynxis Issues | Warranty | Recalls / TSB 7 05-03-2017 04:16 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
pulley not spinning and then spins loud noise Composite Engine, Exhaust, Transmission 19 12-11-2014 07:09 AM
Spinning at Buttonwillow (1CW) ddeflyer Tracking / Autocross / HPDE / Drifting 76 05-22-2014 08:24 PM
Wheel choices got my head spinning!! Trmx2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 11-25-2013 09:34 AM
