Old 01-27-2015, 12:15 AM   #1
Cal3000
Drives: Panda FR-S
Release Bearing or Pilot Bearing
When I release the clutch (push the pedal to the floor) from a dead stop, I hear a squeaking/grinding noise and my car wants to stall.
I've done a lot of forum searches around the web and there seems to be a lot of confusion about which bearing causes this noise in this situation.
Any input?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 01-27-2015, 12:49 AM   #2
steve99
Any input?
we call it a throw-out bearing.
but if clutch not releasing when depressed it likely to be damaged clutch and\or pressure plate unless the bearing is completly ceased. While its apart you might as well replace the lot with an uprated unit if not done already.
Old 01-27-2015, 01:08 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1^^^ Don't try driving it. Have it trailered to the shop if you're not doing the clutch job yourself.
cdrazic93 (01-27-2015)
Old 01-27-2015, 01:56 AM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
+2^
Old 01-27-2015, 02:18 AM   #5
Cal3000
Drives: Panda FR-S
I really have no choice as I don't have any other modes of transportation during the week. I just ordered a new clutch today and wont be getting it until Wednesday. From my research, it seems to be the pilot bearing which isn't as dangerous as a failing throw out bearing which can damage the transmission.
From what I see with my car, there is no noise after the car launches. Only at idle and launch. So the bearing doesn't seem to be in use when cursing. The release bearing(throw out) is constantly spinning when the clutch is engaged.
The Pilot bearing (seated in between the flywheel) connects to the input shaft. The main purpose is to guide the input shaft. So, when I start the car, input shaft has no rotation, pilot bearing begins spinning, then the pilot bearing is in use. When the clutch is engage, the pilot bearing is not in use, so no sound.
Old 01-27-2015, 04:04 AM   #6
steve99
Throw out bearing or thrust bearing is only in use when clutch pedal is depessed its the one that presses on pressure plate fingers to disengage clutch. when clutch pedal is released and your moving in gear it aint used.
see link below, unless we are getting our terminology all messed up due different countries
http://www.ehow.com/about_5456365_throwout-bearing.html
Old 01-27-2015, 10:26 AM   #7
86to86
Drives: FR-S Ultramarine
To test throwout/release bearing:
Drive steady speed somewhere quiet
Push pedal part way down, not far enough to release the clutch
Throwout bearing will spin, pilot bearing will not.
(Is that right? My poor old brain can't work very well this morning)
86to86 is offline   Reply With Quote
Old 01-27-2015, 02:55 PM   #8
Ultramaroon
not playing cards
Pilot bearing spins so the crankshaft can rotate around the input shaft when the clutch is disengaged. Neither pilot nor throwout bearing spin when clutch is engaged.
OP, I strongly advise against driving it but if you insist, learn to shift without the clutch. Refrain from depressing it except to start from a dead stop. This will be your <ahem> crash course in rev matching. It won't last long.
Old 01-27-2015, 05:38 PM   #9
86to86
I was referring to that in-between condition where the stationary clutch fork contacts the throwout bearing, but clutch is still engaged and rotating. If the throwout bearing itself doesn't spin smoothly, it will make noise.
But you're right, this one sounds like it's gone too far and OP probably shouldn't be driving it.
Old 01-27-2015, 07:53 PM   #10
Ultramaroon
not playing cards
Oh, yeah! That makes perfect sense. Then if it starts to squeak or make noise when the clutch is disengaged - pilot bearing.
That's good stuff. Thanks.
Old 01-27-2015, 10:05 PM   #11
Cal3000
Drives: Panda FR-S
From that, I believe it isn't the throwout bearing. There is no noise at constant speeds during shift. There is noise however when I hold the clutch down too long. The input shaft begins to slow down and the pilot bearing begins to spin.
Release bearing always makes noise when the clutch is engaged if it is damaged.
Pilot bearing makes noise when the clutch is pressed.
[ame="https://www.youtube.com/watch?v=boPbjotHSE0"]Clutch release bearing/throwout bearing squealing noise - YouTube[/ame]
I fear the throwout bearing more as that can disintegrate and get caught up in the transmission and cause failure.
Old 01-27-2015, 11:39 PM   #12
Ultramaroon
not playing cards
I've never experienced a pilot bearing failure so I'm especially curious in hearing of the outcome. Good luck with the repair.
Cal3000 (01-28-2015)
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 06:32 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 11:21 AM
Wheel Bearing Woes jwstaton Issues | Warranty | Recalls / TSB 16 01-24-2014 09:06 PM
Thrust Bearing Going Out >(559)< FR-s Issues | Warranty | Recalls / TSB 22 06-19-2013 09:23 PM
bearing identification paraguin Other Vehicles & General Automotive Discussions 7 04-16-2013 11:18 AM
