Old 08-14-2017, 03:25 PM   #1
Zee2413
Drives: Scion FR-S 10 Series
3" Overpipe Clearance issue
Hi. I am getting the Treadstone turbo installed and also a Tomei Expreme Ti Type 80 3" exhaust. I am going with the cat-less setup and the shop is fabricating a 3" stainless steel frontpipe. However, for the overpipe the shop is saying that there isn't enough clearance between the engine and cross member for a 3" overpipe and that I will have to go with a 2.5".
Can anyone advise if this is true? I am seeing some options for full 3" exhaust systems and 3" overpipe.
Thanks in advance.
Zee
Zee2413 is offline   Reply With Quote
Old 08-14-2017, 03:46 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks in advance.
Zee
It's possible but its a VERY tight fit.
I had a custom full turbo kit and full turboback exhaust done by a local shop 3". Never had a rattle, but I know for a fact it was a very tight fit.
Old 08-14-2017, 04:02 PM   #3
Zee2413
Thanks man. I appreciate the feedback. I will relay this to the shop and see what they think.
The Following User Says Thank You to Zee2413 For This Useful Post:
Sportsguy83 (08-15-2017)
Old 08-14-2017, 07:13 PM   #4
Trust86
Drives: 2016 Halo FRS
I believe JDL makes 3" overpipe
Trust86 is offline   Reply With Quote
Old 08-14-2017, 10:08 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
JDL 3" over-frontpipe equipped. Nameless also makes (or made?) a one-piece 3". It has to be exactly right, and probably requires lifting the motor to get it through the gap.
C
Old 08-14-2017, 11:36 PM   #6
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
C
I believe that one of the problems is having a 3.0in overpipe with a flange on it to connect to the front pipe. JDL solved this with having a vband connection, and then Nameless just made it a true one piece if I remember right. Definitely needs to be precisely made so I wouldn't trust any exhaust shop around me at least.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 08-15-2017, 08:53 AM   #7
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I actually have a 3" overpipe built by Treadstone installed on my car right now. I took it loose and wrapped it with heatwrap. It was a PITA to do, but I was able to get it mostly out to do it. So yes a 3 overpipe will fit.
kmbkk is offline   Reply With Quote
Old 08-15-2017, 07:09 PM   #8
Zee2413
Thanks everyone!
Old 08-16-2017, 07:16 PM   #9
Zee2413
Does anyone have any advice on going with the 2.5" instead? With the turbo and Tomei 3" and a 3" front pipe, will I see a significant power loss going with a 2.5" overpipe instead of a 3"?
JDL delivery time is 4-6 weeks and Nameless can't guarantee that they front/over pipe combo will fit with my system. The shop that is doing the turbo work said they won't fabricate a 3", only 2.5".
Thanks in advance.
Zee
Old 08-17-2017, 12:29 PM   #10
Zee2413
Decided to go with the Tomei 2.5" overpipe and the Tomei 3" frontpipe. Hopefully the 2.5" overpipe isn't a big bottleneck and loss of performance.
Old 08-17-2017, 12:50 PM   #11
Detroiter
Detroiter's Avatar
Shouldn't effect performance too much. From what I've seen people have reported around 30whp increase from going full 2.5in to full 3.0in on a turbo setup. Definitely a good gain but with only the overpipe being 2.5 i'm curious if it would be that much of a choke on it.
Raven
Old 08-17-2017, 12:52 PM   #12
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'd be interested to see one brands 2.5" and 3.0" back to back on a dyno tune.
Also I *think* the MXP(?) is a 2.7", so it would be an interesting data point to see the dropoff.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Detroiter (08-17-2017)
Old 08-17-2017, 10:22 PM   #13
Zee2413
Contact from Treadstone sent a note saying due to 2.5" overpipe power loss at max would be 10-15hp. Said it's no big deal but tell that to the $15k I'm spending on turbo, clutch and exhaust...
O well, will have to find a 3" overpipe for next summer.
Old 08-19-2017, 08:07 PM   #14
Amputechture
Drives: 2014 BRZ
Is your downpipe 3 inches? I hear lots of claims of huge 25+ gains from 2.5 to 3 but I have yet to see a dynograph that supports this. I was just looking at midnight23's build journal, he has a Greddy setup and his 2.5/3 inch overlay graph showed gains, but nothing in double digits, and only between the 5k to 6.5k area.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
Zee2413 (08-19-2017)
Overpipe with sway bar clearance? swift996 Engine, Exhaust, Transmission 40 07-05-2020 06:27 PM
Perrin P.S.R.S. clearance issue 15limited Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-11-2017 10:05 AM
Poor Overpipe Clearance JG Engine, Exhaust, Transmission 21 07-15-2015 08:11 PM
Clearance issue Wilson15 Engine, Exhaust, Transmission 0 10-17-2014 02:52 PM
overpipe clearance jamesm Engine, Exhaust, Transmission 12 11-16-2013 01:42 PM
