Old 05-09-2017, 10:06 PM   #1
15limited
15limited's Avatar
Perrin P.S.R.S. clearance issue
After installing Perrin offset control arm bushings I've encountered a problem with clearance between the ball joint end of the control arm and the inside of the rotors. Has anyone else had this problem, or could think as to why I might be experiencing this issue? Lowered somewhere between 1 to 1 1/2 inches on Fortune Auto 500's with -2.5° of camber, Buddy club extended ball joints and Perrin poly bushings, stock rotors.
You can see the scoring of the rotor circled.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 05-09-2017, 10:47 PM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by 15limited View Post
After installing Perrin offset control arm bushings.............
Have you contacted Perrin?
Old 05-09-2017, 10:50 PM   #3
15limited
15limited's Avatar
Not yet, I've only been able to find a couple of threads of people using the part. The forum seems to be the largest wealth of knowledge and much quicker then contacting the manufacture directly.
Old 05-09-2017, 10:57 PM   #4
Captain Snooze
Drives: Red Herring
Huh? I'm not sure waiting for an answer here beats a phone call. I am assuming you are in the U.S. given PNW.
Old 05-09-2017, 11:01 PM   #5
15limited
15limited's Avatar
I'm not going to leave the problem unresolved for weeks on end, and I don't usually have time to call them during the day.
Old 05-09-2017, 11:06 PM   #6
15limited
15limited's Avatar
Whatever, they're your brakes. But it seems you have time to browse the web checking out car forums.
When I'm off work, yes. Thanks for the advice.
Old 05-09-2017, 11:08 PM   #7
Captain Snooze
Drives: Red Herring
My apologies. I didn't check the time there as I posted.
I deleted that comment.
Old 05-11-2017, 09:45 AM   #8
wparsons
wparsons's Avatar
Where was your camber added? Camber plate, or at the knuckle? If you add a bit of camber at the knuckle (either a crash bolt or slotted upper hole), you'll move the rotor away from the LCA a bit. You won't get a ton of clearance, but enough to not rub.
flickr
Old 05-11-2017, 10:05 AM   #9
15limited
15limited's Avatar
Yeah I maxed out SPC crash bolt on the bottom which I think was good for about 1.5° and another degree on the camber plate
Short shifter clearance issue with driveshaft Gank61 Engine, Exhaust, Transmission 16 03-08-2016 06:48 AM
front sway end link clearance issue HELPPP MEEE?!?! BrightSlide Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-09-2015 08:31 AM
Clearance issue Wilson15 Engine, Exhaust, Transmission 0 10-17-2014 02:52 PM
Perrin 3" CBE - S Pipe / cross member clearance? 1Cor10:23 Engine, Exhaust, Transmission 0 05-21-2014 02:06 PM
Perrin drop in figment issue Tiremonkey0824 Engine, Exhaust, Transmission 23 01-11-2013 10:01 PM
