Old 08-01-2017, 03:44 AM   #1
Hawk77FT
Drives: GTS 86
Radiator ducting
All,
I am interested in getting some ducting for the radiator. Is there anyone out there that makes something like that by any chance?
Hawk77FT is offline   Reply With Quote
Old 08-01-2017, 04:05 AM   #2
swarb
Originally Posted by Hawk77FT View Post
All,
Why? Car has more oil cooling problems than coolant problems. Get a oil cooler first.
Imo ducting will have minimal gains over a full setup.
Fan shroud kit, fans and, a radiator is what you should get.
http://counterspacegarage.com/products/cooling.html
Old 08-01-2017, 04:08 AM   #3
Hawk77FT
Drives: GTS 86
Fan shroud kit, fans and a radiator is what you should get.
got an oil cooler already! Need more air coming through the radiator.
thanks for the link
Old 08-01-2017, 04:17 AM   #4
swarb
thanks for the link
The custom ones I've seen is only a block off plate/shield on the sides to direct air towards the center instead of the sides. But that may take air away from your oil cooler depending on where it is mounted. Also look into hood scoop/extractor options to extract air.
Old 08-01-2017, 12:59 PM   #5
Icecreamtruk
Drives: Track preped NA FRS
Hood vents, what you need are hood vents.
Icecreamtruk is offline   Reply With Quote
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post:
czellers (02-09-2021), lantsalot (08-01-2017), norcalpb (03-29-2022)
Old 08-01-2017, 01:16 PM   #6
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Hood vents are definitely a must. If you are still overheating after that, something else is wrong. Ducting would only be a bandaid. That being said. No one has a kit as they will mostly be custom as every car is set-up slightly different. They are decently ducted from the factory.
Old 08-01-2017, 03:58 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Isn't ecu tune governing engaging & rpms of fan? (IIRC there was a way to tune them in OFT). If so, i guess without modding any hardware one can get much more from very same rad, w/o any ducts, without any hood/fender vents.
There is nothing tune can do with oil overheating (except cutting power down), so that's the area you should care about/improve upon.
One can improve capability of rad (not bottleneck) via ducting or hood vents .. but what's a point, if ecu tune just will engage fan later/for shorter time interval/at lesser speeds to compensate? :/
Old 08-01-2017, 05:28 PM   #8
Icecreamtruk
Fans dont do much when the car is moving, OP hasnt specified if he is overheating standing still or when in movement, but something to consider.
Old 08-01-2017, 05:47 PM   #9
lazyluka
Drives: GT86
Have you looked at the ACE solution?
Link
lazyluka is offline   Reply With Quote
The Following 2 Users Say Thank You to lazyluka For This Useful Post:
DustinS (08-01-2017), Hawk77FT (08-01-2017)
Old 08-01-2017, 08:37 PM   #10
Hawk77FT
Drives: GTS 86
Link
I have been looking at that one too. But it looks like I either need to make mine, or buy the whole intake and use the sides and top.
Old 08-01-2017, 09:07 PM   #11
stevesnj
stevesnj's Avatar
All,
Just a few suggestions for engine coolant temp reduction.
If you don't encounter and freezing temps drain some coolant and add distilled water.
Increase the radiator cap to 1.3 bar
To prevent slower driving speed heating up you can have the cooling fans run constant off a switch.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Old 08-01-2017, 09:46 PM   #12
Turdinator
Señor Member
Turdinator's Avatar
OP never said he had over heating issues with coolant or oil. I am not sure why you are all mentioning oil coolers and hood vents etc.
Similar to the Ace solution, HKS Kansai do them as part of an intake setup. LINK
Seems like an expensive way to go tho.
I don't think it would be too hard to fab up your own out of aluminium sheet if you were keen.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Hawk77FT (08-02-2017)
Old 08-01-2017, 09:49 PM   #13
stevesnj
stevesnj's Avatar
You're right
OP what do you need ducting to accomplish?
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Hawk77FT (08-02-2017), Turdinator (08-01-2017)
Old 08-02-2017, 12:33 AM   #14
Hawk77FT
Drives: GTS 86
Originally Posted by stevesnj View Post
You're right
Best air flow through the radiator, and with the help of Velox bonnet vents placed in the low pressure area, achieve the best heat exhaust. Secondary benefit will be the increase in the down force. On the track or spirited driving it would be very good to get these two nailed with minimal modifications!
I had a look at the Kansai ones as well!
The Following 2 Users Say Thank You to Hawk77FT For This Useful Post:
stevesnj (08-02-2017), Turdinator (08-02-2017)
Full Air Ducting thejevans Cosmetic Modification (Interior/Exterior/Lighting) 2 02-13-2021 02:47 PM
Brake Ducting CHEAP! MR2 MK1 to FRS Newbie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-25-2015 11:49 AM
BRZ Premium custom brake ducting ATL BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-17-2015 10:01 PM
Brake Ducting/Hose Routing? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-13-2014 04:20 PM
Custom Brake Ducting. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-09-2012 09:50 PM
