Old 07-31-2017, 01:18 PM   #1
Timmy_Jones
Spun
Drives: 23' Supra
Front Pipe Install and Impressions
I wanted to post my impression of a front pipe install, sound and power differences before and after. First off; the front pipe, I purchased on eBay, it’s a ‘CNT’ 2.5 inch stainless piece with a hi flow cat. I don’t want to post the link, in case I violate a forum rule, but it should be easy enough to find.
Install: Had a friend with a lift, help with the install, otherwise this would have been a huge pain. Car has 22k on it, as of today and the exhaust bolts were pretty nasty. Wire brush and wd-40 we scrubbed them clean and took them off. Old piece slid right out. New one was in and bolted up in about 20 minutes. We went really slow, took the heat shield off, etc. Piece fit perfectly. Total install time was about 90-120 minutes.
Sound: Let me preface this with my current exhaust setup…. Tomei UEL, Tomei Overpipe, STOCK FRONT PIPE, 2.75” catback with mufflers just like the N1 (Manzo V2). Exhaust was loud before, start up especially is borderline embarrassing loud. Its worse now…wow. So loud, so much rasp and fart. Its terrible. If this were the winter time, I couldn’t start the car without being embarrassed. Warm idle is about the same, as before, Deep and loud, sounds great. Driving around, you can notice a bit more ‘growl’ but generally the sound is the same as before, under 3k. Above 3k, the sound is louder and raspier, not too bad. I may even think some of the drone from before is gone! Its just louder now, without as much cabin resonance. With all of this said….I have a ‘real’ catback with a muffler going on the car shortly, just too loud right now. I planned to do this, before I even did the front pipe, even more necessary now. Upon going WOT, the rasp is realy loud and bad. not a good sound here.
Power: I will keep it simple; I have heard claims of 5-7HP and with my setup being almost optimized, except the front pipe, I would say these claims are accurate. I am very happy spending the $200 and think I will be thrilled with a new, more mature cat back installed.
Idle and rev video.
[ame="https://www.youtube.com/watch?v=WO6879wjAoI"]New Front Pipe with Cat - YouTube[/ame]
Timmy_Jones is offline   Reply With Quote
Old 07-31-2017, 01:22 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
It'll feel even better after you get a custom tune.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-31-2017, 01:38 PM   #3
Teseo
Drives: frs
A video will be helpful too
Old 07-31-2017, 03:44 PM   #4
Timmy_Jones
Spun
Drives: 23' Supra
OFT, which I love.
Old 07-31-2017, 03:45 PM   #5
Timmy_Jones
Spun
Drives: 23' Supra
Prior thread, without the front pipe installed. I can do a new video...but its going to sound ugly....
http://www.ft86club.com/forums/showthread.php?t=118152
The Following User Says Thank You to Timmy_Jones For This Useful Post:
Teseo (07-31-2017)
Old 07-31-2017, 05:15 PM   #6
Teseo
Drives: frs
New video with the new front pipe will be helpful too, mine sounds very similar amd want to know how much chamge will do the front pipe and if its worth it
Old 07-31-2017, 10:08 PM   #7
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Plus you can turn off the startup sequence so its not all loud on startup
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
D_Thissen (08-01-2017)
Old 08-01-2017, 08:55 AM   #8
Timmy_Jones
Spun
Drives: 23' Supra
Wish I could...Don't have access to a PC. Unless you know of software which works on a mac?
Old 08-01-2017, 08:56 AM   #9
Timmy_Jones
Spun
Drives: 23' Supra
I will try and get one with the front pipe and then AFTER the new catback as well. Possibly this week.
Teseo (08-01-2017)
Old 08-01-2017, 09:40 AM   #10
bababooey
Drives: BRZ SWP Limited -6MT
ive read on here, there is some program for mac that mimicks windows. pc user here so im not terribly familiar but a solution does exist.
Old 08-01-2017, 09:46 AM   #11
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Before I finished building my pc, I used bootcamp on my macbook to tweak OFT tunes in windows. Bootcamp should come as a stock program on macs, and it allows you to boot up in either OSX or Windows of your choice.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
bababooey (08-01-2017)
Old 08-02-2017, 10:38 AM   #12
Timmy_Jones
Spun
Drives: 23' Supra
WOT with this setup sounds terrible..updated the original post. So much rasp and 'tin' sounding to it.
Old 08-02-2017, 10:33 PM   #13
Darkrune
Darkrune's Avatar
Drives: 2017 86
Yep. That FP is poop.
Sent from my SM-G935V using Tapatalk
Darkrune is offline   Reply With Quote
Old 08-03-2017, 01:43 PM   #14
Timmy_Jones
Spun
Drives: 23' Supra
Video added....but its only idle and a tiny rev, which I think sounds great.
Front Pipe Install appa234 Engine, Exhaust, Transmission 8 07-01-2017 04:29 PM
Rattle after front pipe install Decimus Engine, Exhaust, Transmission 6 01-25-2015 05:03 PM
cel after front pipe install assbox Engine, Exhaust, Transmission 18 11-26-2013 02:02 PM
Catless front pipe install? bdanisi Southern California 7 08-22-2013 08:26 PM
Assistance on DIY front pipe install. Osiris DIY (Do-It-Yourself) Guides 3 04-18-2013 10:31 PM
