frank
Drives: Subaru BRZ WRB
Hello,
My 2013 BRZ's left headlight high beam stopped working while ago. I checked the fuse first, and couldn't find any fault. I replaced them anyways but that didn't fix the problem. After a while, I finally got myself a replacement bulb set. It still wasn't working after that. I checked fuse again, and nothing wrong. Am I missing something here? Is there some other fuse I should check other than the ones that are labeled high beam? My right side headlight high beam is working fine.
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA Build Photo Album - http://bit.ly/brz_wrb SoCal LA 86 Club Member ![]() |
I took this from an old post.
"At least for the FR-S, I know that there is a relay (white/offwhite box) in the fuse box labeled "DRL" that controls both the high beams as well as DRL function, not sure about the BRZ though because it's headlights are OEM hid and LED boomerang DRL. If that relay were the issue then both headlights wouldn't be able to have DRLs or high beams not one. I suggests pulling or tugging on the wires coming from the pins on the connectors with the high beams on to see if it flashes on that side or something." That might be worth a try. humfrz |
| HID vs LED Low/High beam along with DLR? | xFury | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 12-15-2015 11:15 AM |
| DRL or high beam or both? | jacobzking | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 06-09-2013 03:09 PM |
| HID and high beam use | gatorbushmen | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 04-19-2013 04:56 PM |
| High beam/LED question | Trashed675 | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 01-20-2013 12:46 PM |
