Old 01-19-2013, 12:54 AM   #1
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
High beam/LED question
As i understand it, our high beams are 9005 type bulbs that also act as the parking/running lights. So if you replace the OEM bulbs with LEDs wouldn't you be giving up your high beams? I'm guess i'm just having a little trouble understanding how the OEM bulb works as both high and DRL.
Trashed675 is offline   Reply With Quote
Old 01-19-2013, 12:56 AM   #2
Mo707
Mo707's Avatar
I have LEDs for mine they would work the same as OEM. low when the brake is down and a lot brighter when you turn on the high beams.
Mo707 is offline   Reply With Quote
Old 01-19-2013, 12:57 AM   #3
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
you dont loose your high beams. it will still shine when you flick the switch. but it wont act as high beams because LED does not have the range and light output as OEM bulbs
in short high beams is useless with LEDs
86_ZN6 is offline   Reply With Quote
Old 01-19-2013, 12:59 AM   #4
Mo707
Mo707's Avatar
Wait what? I have HID's for my head lights and and LEDs for my high beams and it works just fine.
Old 01-19-2013, 01:08 AM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
yes it works! it still lights up but the High beam LEDs wont outshine the low beams, making it useless
the main point of the high beams is to outshine the low beams.
Old 01-19-2013, 10:52 AM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I second @86 ZN6. They look good, but I can't even tell when my high beams are on.
Old 01-19-2013, 12:28 PM   #7
Trashed675
Trashed675's Avatar
That is exactly the answer I was looking for, thank you!
Old 01-19-2013, 01:05 PM   #8
nbafandan
Phantom
Drives: Whiteout MT
But the lowbeam HIDs make up for the lack of highbeams right?
nbafandan is offline   Reply With Quote
Old 01-19-2013, 02:30 PM   #9
boredom.is.me
Custom User Title
Not if you are the only car on a not lit road.
Old 01-19-2013, 03:12 PM   #10
Trashed675
Trashed675's Avatar
And not if you don't have HID's to begin with
Old 01-19-2013, 06:52 PM   #11
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
I guess the best way to figure out if you can live with the absence of high beams is the amount of time you drive at night and on unlit roads. Especially if there are hills and curves. I find that I'm not willing to out drive my lights without high beams but having non-retrofitted HID's has a slight benefit in that regard.
I've driven against my car in an oncoming test and find that the lack of a "proper" cutoff from a retrofit is acceptable.
If I had a retrofit with the poper cutoff, I would NOT like the inability to use my high beams, that's for sure.
Heck, even some OEM HIDs are untolerable at times.
CircuitJerk is offline   Reply With Quote
Old 01-19-2013, 10:48 PM   #12
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
if u still want the high beam feature, go with some silverstars or piaa bulbs ... which is what i think im going with.. i dont want the loss of the high beam feature when i drive up to the poconos
mikeg7827 is offline   Reply With Quote
Old 01-19-2013, 11:06 PM   #13
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
I keep my stock bulbs in my glovebox just incase I neeed them.
It doesnt take 10 secs to swap them out
Old 01-20-2013, 05:07 AM   #14
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
i have silver star ultras and 6000k hid. The silverstar is very yellow compared to the hids.
mrlewistan is offline   Reply With Quote
Bumper Beam Delete? Anorexic 86 Tracking / Autocross / HPDE / Drifting 25 11-04-2014 01:41 PM
Low beam on indicator? percyng CANADA 5 10-10-2012 04:47 PM
