Drives: scion fr-s
after resetting ecu
how long does it take for ecu to relearn everything again ?
Senior gif poster
Drives: 2013 Asphalt FRS
I think it is 100 miles. I put a new battery in the FRS today and I followed these steps after connecting the battery before I actually started the car.
Turn the ignition to on, but don't start the motor press the gas pedal all the way to the floor slowly and steadily - take about 3 seconds to get to the floor slowly and steadily release the gas pedal back up - again, about 3 seconds repeat the press and release for a total of 5 complete down-up cycles turn the ignition off When I started the car after that everything was fine no rough idle or anything. You can try disconnecting again and following those steps. |
Their is no time or distance. Ecu continuously learns fueling and timing corrections. After a reflash/reset it needs to calibrate some initial settings with cams throttle etc. see here http://www.ft86club.com/forums/showt...30#post1803730 |
| Resetting ECU after cleaning MAF? | Hentai | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 12-15-2015 03:28 PM |
| Resetting the ECU after running 87 gas | orangespark | FR-S / BRZ vs.... | 10 | 08-29-2015 05:23 PM |
| iPod Keeps resetting, hanging; etc... Anyone else seeing this | Max1957 | Electronics | Audio | NAV | Infotainment | 5 | 03-17-2014 09:41 PM |
| Advance Mutiplier resetting on restart? | feldy | Software Tuning | 122 | 11-05-2013 11:08 AM |
