Old 11-26-2015, 09:28 PM   #1
Hentai
Hentai's Avatar
Drives: 2015 Halo GT86
Resetting ECU after cleaning MAF?
I just cleaned my MAF with CRC maf cleaner
Just wondering if resetting the ecu (disconnect battery)
& letting it idle for the first 10-15mins would make any difference in it's learning process again?
Or should I just drive and let it learn from then on
Thanks
Hentai is offline   Reply With Quote
Old 11-26-2015, 11:49 PM   #2
steve99
Ecu is always learning no need to reset, only need to reset to clear cel codes
see Flashing-Reset-Learning link below
Old 11-27-2015, 07:59 PM   #3
humfrz
Yep, like @steve99 says ...... the ECU is pretty smart.... it will figure it out ......
humfrz
Old 11-28-2015, 10:19 AM   #4
KendallH
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
Why did you clean your MAF? That can do damage to the sensor. These cars are not like older vehicles.
KendallH is offline   Reply With Quote
Old 12-15-2015, 02:28 PM   #5
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
The CRC maf cleaner is pretty safe, should cause no damage there. Letting the battery remain disconnected for a little while will reset the ECU though it's not entirely necessary. Essentially it shouldn't make a difference but it won't hurt.
Gear_One_Performance is offline   Reply With Quote
Resetting the ECU after running 87 gas orangespark FR-S / BRZ vs.... 10 08-29-2015 04:23 PM
Radio shutting off/resetting itself while driving Eski Electronics | Audio | NAV | Infotainment 7 05-21-2015 09:06 PM
iPod Keeps resetting, hanging; etc... Anyone else seeing this Max1957 Electronics | Audio | NAV | Infotainment 5 03-17-2014 08:41 PM
Advance Mutiplier resetting on restart? feldy Software Tuning 122 11-05-2013 10:08 AM
