Drives: 2017 Asphalt 86
GCS 4th brake light wire taps
So, I installed this last night. Working great, but now today the brake light portion isn't coming on at all. I'm assuming the wire taps they gave me are garbage. Should I cut the wires and use a wire nut, is there enough slack in the stock harness to get extra wire for that? Also debating using the splices that have a spade connector.
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Would butt splices work, if I cut and spliced the wires together?
I hate the idea of cutting the stock wires. But if it's a solid, more permanent connection. Why not Last edited by Tysoncrosby21; 04-06-2017 at 01:59 PM. |
| DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video | continuecrushing | DIY (Do-It-Yourself) Guides | 44 | 11-23-2020 07:17 PM |
| Valenti 3rd Brake Light Wire Mapping | Anal0g | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-24-2016 11:36 PM |
| OEM NEW 4th Brake/Fog light with OEM complete wire harness | Oliverrick | Exterior Parts (Aero, Lighting, Etc.) | 0 | 04-02-2015 02:29 PM |
| How to wire a fog light switch to Diode Dynamics fog light kit *SOLVED | tiz22 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 06-04-2014 02:16 AM |
| FS: Wire taps + resistors (for LED turn signals) | Laika | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-13-2013 10:50 AM |
