Old 06-28-2016, 02:31 PM   #1
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video
So, there seems to be a lot of threads/questions about how to wire the Valenti 3rd/4th brake light and modify it to work/flash differently. There are wires/cutting/moving/combining/arrows all over etc-I've done this mod before and I was confused by the differences in pictures (upside down/jumper wires all over/new wires added).
When done correctly, there wont be CEL, weird dimming or any other bizarre electrical issues.
There are 3 Main ways of having the Valenti Rear wired
1. Stock out of box-When you turn on the running lights, the "V" AND the center triangle light up. When you step on the brakes, the center triangle flashes 3 times and then remains on. This is less than ideal I suppose, since most of us only want the center part to light up when you step on the brakes-which brings us to the mods we can do!
2. (flashing) When you turn on the running lights, only the "V" will light up. When you step on the brakes, the center light will flash 3 times, and remain on-as long as you step on the brakes. When you release the brakes, the center light will turn off.
3. (Not flashing)When you turn on the running lights, only the "V" will light up. When you step on the brakes however, the center light will turn on-and will remain on until you release the brakes.
The video here shows the different methods AND how the wiring should be setup.
I will have another video shortly that shows which wires to tap into on the tail light side/reverse side-but that content is out there...wasn't a top priority for me. Picture is below
[ame="https://www.youtube.com/watch?v=LyQSlMxT5RA"]DIY: Valenti 4th Brake Light Wiring Mod- HOW TO -Separate "V" and Brake - YouTube[/ame]
How the wiring looks OUT OF THE BOX. Before modifying.
HAD TO UPDATE-WILL ADD NEW PHOTOS HERE SOON
I'll need to check to see how "plug and play" the harness is on the 4th brake light, might just have to pull/tap the red/blue wire into the tail light.
Old 06-28-2016, 03:18 PM   #2
continuecrushing
for future content
Old 06-28-2016, 06:34 PM   #3
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Where was this 2 years ago before I paid someone to mod mine?! Lol jk, thanks for finally posting a DIY on this!
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
Old 06-29-2016, 08:12 AM   #4
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
sick, i was finally going to try this over the weekend based on another thread..
xDBOYx is offline   Reply With Quote
Old 06-29-2016, 11:33 AM   #5
continuecrushing
let me know if you have any questions on any of this, I tried to make it simple.
The other threads did okay, but it seemed overly complicated in some of them? I don't know lol.
Old 06-30-2016, 05:09 AM   #6
j_motion
Drives: 14 BRZ Red premium
This is the way i wired up for my V and flasher brake
I use a Jumper cable between the black and orange to connect the stop and fog solder point.
I think is essentially the same as your wiring.
But with the way im connected there were interference with some of the electrical system in the car.
on the BRZ..
If you wire it up like how it is in my image.
The moment you step on brake.(well at least on my car)
The boomerang light and side marker will turn on. Also at the same time The clock display go blank.. and the air bag and driver seat sing on the right hand side of the clock will dim.
When you release the brake,
Clock display come back and other light not dimmed.
Boomerang light and side marker goes off.
Another member has notice the same problem, and here are his solution to it.
I didnt get the chance to take it off to try it out yet.
Originally Posted by mchasteen1 View Post
I meant to add a follow up to this, but I got distracted. The wiring DID cause issues for me as well. Powering the V with both the running lights AND the brake light caused feedback in the system that affected other lights (center console and parking/indicator lights for me).
The solution was to take the V off the brake light. That means I connected the red wire directly to the green wire so that it doesn't touch the board at all. Straight up red to green. I've had no problems since then.
Just want to see if the way your wire up with the Orange and black wire going to Stop and Fog solder point having the same issues as me by using a jumper to bridge it.
Cheers
j_motion is offline   Reply With Quote
Old 06-30-2016, 11:14 AM   #7
continuecrushing
hmm, I need a brz for testing lol
and, for reference, the jumper method and my method are essentially the same.
The method in question is this?! I BELIEVE this makes sense. Otherwise, whats happening is you set on the brakes with no running/parking lights on and power goes BACK through the system and essentially powers the running/parking lights.
I will need to test and report back, but this does seem to be correct.
Example below:
Remove the green wire from the solder joint(yellow arrow), and attach the red wire to the green wire(light blue arrows).
Old 06-30-2016, 08:47 PM   #8
continuecrushing
@j_motion I was wrong!(about the original video/wiring)
I believe removing the green wire from the board and having the red wire connect directly to it is the way to go.
BUT, I will check tomorrow and update the video!
Old 07-01-2016, 04:43 AM   #9
j_motion
Thumbs up
sounds good
thats what mchasteen1 did on his FRS to fix the interference problem
Old 07-01-2016, 08:27 PM   #10
continuecrushing
re-shot the video, will have it uploaded tonight perhaps!
Old 07-02-2016, 05:21 AM   #11
continuecrushing
okay, new video up with PROPER way to wire!
Old 07-03-2016, 03:14 PM   #12
j_motion
From now on this will be the new brainer's post to the valenti's install
Old 07-05-2016, 02:29 PM   #13
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Just to be clear, is this for the bottom light that FT86 SpeedFactory sells, or is it the legit Valenti light? Or does that even matter?
Silver Cervy is offline   Reply With Quote
Old 07-05-2016, 03:39 PM   #14
continuecrushing
This is for Valenti lights...so it shouldn't matter as long as its a "valenti" light.
valenti, valenti mods, valenti wiring
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
WTB: Valenti 4th Brake Light thecarfilmer Want-To-Buy Requests 1 05-22-2016 07:50 PM
Valenti 4th brake light vs Valenti Style brake light? JGalp Electronics | Audio | NAV | Infotainment 9 03-24-2016 05:48 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
how to turn that rear triangle reflector into working brake light chris's fr-s DIY (Do-It-Yourself) Guides 29 06-10-2013 07:25 AM
