Old 02-01-2017, 11:19 AM   #1
Tysoncrosby21
Drives: 2017 Asphalt 86
O2 sensor for header.
I know, I know the o2 spacer isn't a permanent fix. But until I get my OFT, I want to try to delay a CEL as long as possible. So, do I get the straight on spacer, or the 90 degree bend spacer. I'll be using the gruppe s header if it makes a difference.
Tysoncrosby21 is offline   Reply With Quote
Old 02-01-2017, 11:47 AM   #2
Teseo
Drives: frs
Cheap obd2 and remove cel
Old 02-01-2017, 12:19 PM   #3
Tysoncrosby21
Huh?
Old 02-01-2017, 12:43 PM   #4
Teseo
Drives: frs
Using that to remove check engine light until your oft arrives
Old 02-01-2017, 01:02 PM   #5
Tysoncrosby21
So, don't even bother with a spacer?
Old 02-01-2017, 01:06 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
The CEL will come back though if you just clear the code.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-01-2017, 01:10 PM   #7
Tysoncrosby21
My thought is, slap a spacer on for now. Ross my fingers and see what happens.
Old 02-02-2017, 12:25 AM   #8
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
How long do you need to wait for the OFT? I would just wait if I were you. Not worth dealing with constant CELs.
demasrv is offline   Reply With Quote
Old 02-02-2017, 12:47 AM   #9
renfield90
The Stig's German cousin
Just ignore it? The worst that happens is you might get kicked to the safe map and go without some power for a bit, unless we are talking months on end (risk of missing a more important CEL).
Header 02 Sensor Question sroby Engine, Exhaust, Transmission 2 09-28-2016 02:21 PM
Header install: O2 sensor wiring? ouij Engine, Exhaust, Transmission 3 06-06-2016 10:40 AM
Installing JDL Catted Header. Front O2 sensor wiring too short! BFIFE22 Engine, Exhaust, Transmission 5 03-13-2016 04:10 AM
Installed JDL Catted Header. Front O2/AFR sensor too short! BFIFE22 Engine, Exhaust, Transmission 3 03-12-2016 11:21 PM
Broke Oxygen Sensor during Header Replacement - Can i run w/o one? Adeel Engine, Exhaust, Transmission 7 05-20-2014 03:12 PM
