Drives: 2013 GBS BRZ Limited
Installing JDL Catted Header. Front O2 sensor wiring too short!
So I'm on the tail end of the install, and went to reconnect the harnesses for the 02 sensors. The one after the cat (the black connector, if I'm correct), reaches fine. The front one (grey connecter) doesn't have long enough wiring to reach the connector. Has anyone else run into this on their header install?
Is it possible to extend the sensors wires at all if need be?
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
Drives: SWP BRZ
buy o2 extender
Drives: Raven FR-S 6M
Swap your sensors. They are in the wrong holes
“The World is Flat”
[||•]=(86)=[•||] |
Remember the front O2 sensor is between the engine exhaust port and the cat. Right in front of the engine. The cat sensor which is longer and has a black connector is by the right fender and after the cat in relation to the exhaust flow.
http://www.gt86.org.uk/forums/topic/...eresting-read/
“The World is Flat”
[||•]=(86)=[•||] |
The O2 sensors were in the correct bungs. That was my first thought to check though.
The front one was just too short by about an inch. I ended up just having to unclip the top harness from it's mounting point which moved it just close enough to clip the harnesses together. No CEL or anything so far today so I should be set.
Drives: 2013 Scion Fr-s
I had this problem with my JDL headers too. I couldn't put them in each clip in place and they are kinda just hanging there. they are tight enough to not move around.
| Installed JDL Catted Header. Front O2/AFR sensor too short! | BFIFE22 | Engine, Exhaust, Transmission | 3 | 03-12-2016 10:21 PM |
| catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
| Catted header or catted front pipe? | wilfredwong | Engine, Exhaust, Transmission | 5 | 02-09-2015 06:11 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| FS: Tsudo header back exhaust w/catted front pipe | Opposed | Engine, Exhaust, Bolt-Ons | 4 | 11-19-2013 01:01 PM |
