Old 09-27-2016, 11:11 PM   #1
sroby
Drives: 2015 Firestorm 08/05/15
Header 02 Sensor Question
I am currently running the Shiv,s open flash with Grimm speed intake and stage 1 flash. I am planning my header install and stage 2 mapping. I understand running the stage 2 will eliminate the cel light and engine check light. If the stage 2 turns it off to the ecm, is it necessary to then reinstall the o2 censors. Can I just keep the plugs in the header and leave the o2,s unplugged from the connector thus keeping them out of the exhaust stream since they wont be working any way. I am asking because in 2002 I owned a VFR v-tec. I was running a power commander decatted headpipe with a staintune exhaust. The power commander came with 02, foolers that you plugged into the factory harness. I believe they were just asset of resistors because you didn't have the ability at that time turn them off in the ecm. I didn't know if I needed to keep them plugged in to complete the circuit. thanks in advance. regards Steve
sroby is offline   Reply With Quote
Old 09-28-2016, 03:02 AM   #2
steve99
The tune just disables the cat efficiency cel code. it does not disable the 02 sensors.
You still need both 02 sensors functioning for afr readings
reinstall both 02 sensors in new header in correct positions do not use any spacers or de-foulers on either sensor.
Old 09-28-2016, 01:21 PM   #3
sroby
Thanks sir that's exactly what I needed to know. Damn I had everything covered except the A/f ratio,s Doohhh. Appreciate it partner very much. regards Steve
O2 sensor question: which is before cat, which after j_Zer0 Engine, Exhaust, Transmission 9 10-25-2017 01:47 PM
Header install: O2 sensor wiring? ouij Engine, Exhaust, Transmission 3 06-06-2016 09:40 AM
New MAP sensor question SkAsphalt Software Tuning 2 07-15-2014 04:23 PM
Broke Oxygen Sensor during Header Replacement - Can i run w/o one? Adeel Engine, Exhaust, Transmission 7 05-20-2014 02:12 PM
Map Sensor Question SunkenFRS Engine, Exhaust, Transmission 1 03-11-2014 04:41 PM
