Old 03-12-2016, 05:24 PM   #1
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Installed JDL Catted Header. Front O2/AFR sensor too short!
So I'm on the tail end of the install, and went to reconnect the harnesses for the 02 sensors. The one after the cat (the black connector, if I'm correct), reaches fine. The front one (grey connecter) doesn't have long enough wiring to reach the connector. Has anyone else run into this on their header install?
Is it possible to extend the sensors wires at all if need be?
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 03-12-2016, 05:40 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This may possibly help:
[ame="http://www.amazon.com/O2-Sensor-Spacer-Adapter-Extender/dp/B00CZFCPQU"]Amazon.com: O2 Sensor Spacer Adapter Extender: Automotive[/ame]
Old 03-12-2016, 06:15 PM   #3
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Just don't bother clipping the harness into its mounting points, it can't exactly go anywhere now that it's pulled tighter. Mine BARELY reached on my uncatted JDL, I left one of the little "christmas tree" clips undone to prevent any stress. No issues in a year and a half and a bunch of abuse
Old 03-12-2016, 10:21 PM   #4
BFIFE22
BFIFE22's Avatar
That's what I ended up doing. Theres enough tension on it to keep it in place without pulling too hard on it. Good to hear that it shouldn't cause issues!
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
Catted header or catted front pipe? wilfredwong Engine, Exhaust, Transmission 5 02-09-2015 06:11 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
HKS Legamax with Berk Tech Catted front pipe installed Firestorm_86 Engine, Exhaust, Transmission 2 03-16-2014 10:56 PM
FS: Tsudo header back exhaust w/catted front pipe Opposed Engine, Exhaust, Bolt-Ons 4 11-19-2013 01:01 PM
