Old 12-12-2016, 08:06 PM   #1
Hawker271
Drives: Scion FR-S 2013
Trunk Buzz After Sub install
Hello everyone,
I'm posting to see if anybody has the same issue before I pull my car apart going crazy over this buzzing sound. When the bass of my sub rumbles at low notes, it creates a buzz coming from what almost seems to be from the wheel well. I put my head in the trunk and it sounds like it's coming from inside and below these two locations.
If anybody has the same issue and has fixed it, help would be much appreciated ^.^.
Hawker271 is offline   Reply With Quote
Old 12-12-2016, 08:30 PM   #2
humfrz
Well, the first thing I'd do is to remove everything from the wheel well, then fire up your bass and see if something still vibrates.
humfrz
Old 12-12-2016, 08:42 PM   #3
Start hitting things with the palm of your hand until it stops. This is not a joke that is the first thing I would do under those circumstances.
Old 12-12-2016, 09:31 PM   #4
ryoma
ryoma's Avatar
pull up the cover and check your spare/tools. it might be the jack vibrating
Old 12-12-2016, 11:50 PM   #5
Hawker271
Thanks for the reply guys, I'll do all those things!
Old 12-13-2016, 12:57 PM   #6
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
I was definitely going to say it's something under the floor with your spare.
Might it also be the rear parcel shelf? (where the third brake light is) I just installed a sub and amp last week and the parcel shelf seems to be where most of my rattles are coming from.
Good luck.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
Metallic buzz over 4000 rpm? Ingen Issues | Warranty | Recalls / TSB 37 11-21-2017 01:51 PM
Duckbill trunk install to IFO - Subaru BRZ - HAWAIICALIVEGAZ Cosmetic Modification (Interior/Exterior/Lighting) 4 01-02-2016 03:16 AM
Slight buzz at 1,500 RPM ericmpena Engine, Exhaust, Transmission 5 05-02-2014 08:35 AM
Anybody Have this Buzz/Rattle? Gary in NJ BRZ First-Gen (2012+) — General Topics 8 10-07-2013 12:36 PM
