Old 04-30-2014, 08:17 PM   #1
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Slight buzz at 1,500 RPM
Hey guys, I've had my Greddy SP Elite installed for maybe 2 months now. Ever since the install I've heard a very slight buzz right then the car goes passed 1,500 rpms. I can hold the RPMs right at 1,500 and hear the buzz. What should I check for?
I'm sure it's a simple issue, but I'm not one for tackling something I know nothing about. Thanks!
ericmpena is offline   Reply With Quote
Old 04-30-2014, 08:19 PM   #2
Malt
Drives: 2015 WRX
resonance from your exhaust is the most likely cause.
Malt is offline   Reply With Quote
Old 05-01-2014, 01:45 AM   #3
ericmpena
ericmpena's Avatar
That's what I figured. Just curious if that something normal when you get aftermarket exhaust or if something is loose.
Old 05-01-2014, 03:32 PM   #4
no1r
Showboater Nazi
Drives: 2014 Whiteout FR-S 6M/T
It's just vibrating and hitting something on the bottom of the car. My Evo3 has the same vibration at 1.5K RPM - nothing to be worried about to be honest, it sounds blah, but no damage is being done. Next time you jack it up, just make sure everything has enough clearance and pull any pipes farther downward to make sure nothing is even close to touching.
no1r is offline   Reply With Quote
Old 05-02-2014, 06:47 AM   #5
Sphirit
Drives: GT86
I have the greddy SP elite since 3 months and all is perfect, maybe a little bit drone at 1.400rpm but nothing important
Sphirit is offline   Reply With Quote
Old 05-02-2014, 08:35 AM   #6
dbrandt01
Drives: none
Is it more like a rattle than a buzz? if so, I second no1r above. I had that problem on my truck. Piping was hitting the bottom of the truck and rattling. Just had to loosen it up and shift the pipes a bit.
dbrandt01 is offline   Reply With Quote
Metallic buzz over 4000 rpm? Ingen Issues | Warranty | Recalls / TSB 37 11-21-2017 01:51 PM
Rattle/buzz with certain bass tones. Tyler. Electronics | Audio | NAV | Infotainment 6 05-03-2014 08:15 AM
Anybody Have this Buzz/Rattle? Gary in NJ BRZ First-Gen (2012+) — General Topics 8 10-07-2013 12:36 PM
Installed Amp & Speakers, getting constant buzz Gir Electronics | Audio | NAV | Infotainment 8 11-16-2012 02:28 AM
Continuous BUZZ/HUM from HPFP in ACC mode. stevo_12v AUSTRALIA 2 10-22-2012 05:46 AM
