Old 12-04-2016, 11:12 PM   #1
Nah
Drives: 2013 Scion Frs 6mt
Throttle Pedal Sensitivity
Hello everyone,
Thank you for reading.
I am asking the community for some help with my throttle pedal.
I've done everything this community has to help but honestly It's not where I want it to be.
No matter what I do... I still cannot get my throttle pedal to be smooth.
I've dialed in my tune. Trims are in within 3% everywhere. Cams have been adjusted by adding 2 degrees starting with the intake.. Timing is advanced uniformly where needed. I've ran DI from .1 to .3...
DI up until .3 is the sweet spot for an aggressive street tune.
Adjusting torque requested tables so they are more linear. This helped tons with high RPM throttle sensitivity.
I changed my throttle activation from 1.5 to 1%. That seemed to help too but I'm not to sure I have to test a different setups.
Please any help is appreciated. I've tested many different theories and the ones on here have always worked out perfectly. I'm done with the dial in. Is there anything else I can do to "fine tune?"
Nah is offline   Reply With Quote
Old 12-05-2016, 12:26 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
Can you be more specific about what you don't like? Do you have the manual or auto gearbox?
1974 TA22 Celica
2013 86 GT
Old 12-05-2016, 12:38 AM   #3
phrosty
Have you tried replacing foot?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following 2 Users Say Thank You to phrosty For This Useful Post:
BXRCHTR (12-05-2016), Wayno (12-05-2016)
Old 12-05-2016, 01:39 AM   #4
504
504's Avatar
Drives: 2014 86 GTS
I think alot of people including myself think that the on off throttle jerk is tune related, upgrade rear subframe bushings and you'll be laughing
504 is offline   Reply With Quote
Old 12-05-2016, 04:09 AM   #5
aagun
Drives: 86
nah is it custom or stock rom that u apply the change?
aagun is offline   Reply With Quote
Old 12-05-2016, 12:07 PM   #6
Nah
Custom tune using Wayne's definitions. Manual. I'm going to upgrade those bushing and get back to you guys with a B&A. What bushings did you go with?
Basically it's just a jolt when just pressing the throttle when cruising to accelerating. Mainly in the 3-4k range.
Old 12-05-2016, 12:08 PM   #7
Nah
my foots pretty big don't see a need to replace it...
Old 12-05-2016, 01:31 PM   #8
chas3wba0
chas3wba0's Avatar
Drives: Yes
Have you driven on the same tune for a at least a week without flashing? After flashing a new tune, it is normal for the throttle sensitivity to be off... usually takes a few drive cycles to get better.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 12-05-2016, 01:35 PM   #9
Nah
Yes of course. And if you slowly push the throttle with the key in the on position the ECU will learn the movement much faster
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Sloppy throttle pedal allowe Engine, Exhaust, Transmission 23 11-02-2016 02:11 PM
Tire sensitivity to inflation pressure babydriver Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-20-2015 11:39 AM
Throttle Pedal Lag gonzo Software Tuning 4 08-29-2014 02:07 AM
