Old 02-18-2015, 08:26 AM   #1
babydriver
Hit the road and I'm gone
babydriver's Avatar
Tire sensitivity to inflation pressure
I've noticed on my FR-S that relatively small differences in tire inflation seem to make pretty big differences in handling. Recently, I purchased a racing tire gauge that is accurate to 0.1 lbs of air pressure. Setting the inflation to 35 psi (all within a tenth of a pound) seemed to make a big difference. I was able to take my favorite wide sweeping curve at 80 mph with ease, a full 5-10 mph faster than previously. I could probably go faster, but don't want a big fat ticket!
I don't necessarily know if the factory recommendation is ideal for handling. I am not that interested in drifting, so I'd like to keep the rear end under tight control in the curves. Any experiences out there with changing this factor?
Thanks!
Slip, slidin' away.
Old 02-18-2015, 11:38 AM   #2
RFB
RFB's Avatar
Drives: FRS
Thanks!
I have found that -
Any change in pressure ratio between the front and rear alters handling, and I experiment making rear or front harder depending on the track, to balance the oversteer - understeer. (Harder rear than front - more oversteer, etc.). The amount of traction increases as the tire gets softer and gives more road contact.
Seems just after several laps of adjustment, just when I get it right for the track, temp, etc., the conditions change !
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
babydriver (02-18-2015)
Old 02-18-2015, 11:46 AM   #3
On here someplace is a 500 post debate on tire pressures. Not sure how valuable it would be though as I am pretty sure it delves in quantum physics a few time!
Old 02-18-2015, 01:28 PM   #4
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
The ONLY time I've ever been aware of my tire pressure was after a service on my '03 Suzuki SV1000S. A local dealership who I won't name (Mount Baker Moto Sports) had overfilled both tires. I felt like I was going to tip over and fall off at any moment. Pulled over after about two blocks and checked the tires...50psi!!! I let some air out and went about my day, feeling fortunate to be alive. F***ing scary. :-/
NWFRS is offline   Reply With Quote
Old 02-18-2015, 01:32 PM   #5
jvincent
jvincent's Avatar
Tire pressure, and more specifically HOT tire pressure, definitely has an impact on the track.
There's no hard and fast rule though since it it track/tire/driver preference dependent.
When I switched from the stock tires to Hankook V12's I just picked a HOT pressure as a starting point and then experimented up/down from there.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
babydriver (02-18-2015), wparsons (02-20-2015)
Old 02-18-2015, 02:36 PM   #6
CatDaddysBBQ
Drives: '13 FR-S
I found that 34-36psi was good for the oem tires. Less than that and you'd roll the sidewalls in autoX, and anything over 38 was like a plastic tire and would understeer like on ice.
This year I've upgraded and I get to test and adjust to find a new good area. Fun "problem" to have!
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
Old 02-20-2015, 11:25 AM   #7
babydriver
babydriver's Avatar
I tried using 35 psi on the front and 34 psi on the back tires to see if I could increase traction. Did not like it at all! The steering became unpredictable and a little scary with the rear end having a mind of its own. I put them all back to 35 psi for now. The car returned to going where I point it without drama.
I plan to try 34 psi on all four tires and see how that works.
Slip, slidin' away.
Old 02-20-2015, 11:35 AM   #8
wparsons
wparsons's Avatar
I have a feeling it's more in your head than anything. Altering pressure by a couple psi isn't going to give you enough more grip to go 5-10mph through a corner.
Same goes for the car handling wildly different by changing pressure by 1psi at one end.
Pressure is definitely a valuable tuning aid, but you need more than a 1psi difference to make a big difference.
flickr
Old 02-20-2015, 11:39 AM   #9
vroom4
No doubt. 3-4 psi maybe. 1 psi, no.
vroom4 is offline   Reply With Quote
Tire Inflation Pressure mslerner2002 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 05-14-2014 10:52 AM
Tire Pressure for PSS? Pacific Auto Tracking / Autocross / HPDE / Drifting 12 01-22-2014 10:50 PM
tire pressure mrnibbs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2013 10:09 AM
Tire Pressure Fallen43 CANADA 2 10-12-2013 12:46 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
