Old 08-21-2014, 03:55 PM   #1
gonzo
Drives: frs
Throttle Pedal Lag
Is there anyway to get rid of this lag? Driving my friend's evo made me realize how bad it is. At least the lag isn't nearly as bad as my friend's 06 civic si (my god it's terrible).
I have OFT but I'm pretty sure it was just as laggy while stock.
gonzo is offline   Reply With Quote
Old 08-21-2014, 04:01 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
I'm on the 2.01 maps and my pedal feels more responsive than stock..there's always gonna be lag in a dbw pedal.
Old 08-26-2014, 10:13 AM   #3
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i dont think it will ever feel like a cable car. my friends evo 8 feels crazy so i know what you mean. Response will never be the same, its too many electronics
IG-Joey_Soul
Old 08-26-2014, 10:48 AM   #4
steve99
OFT tunes make very little changes to the DBW (drive by wire) throttle tables the only changes in latest tunes are at high rpm.
Check your fuel trims, log your LTFT it should be less than 5% throughout rpm range.
Changing intakes can throw off maf scaling and cause hesitation
If your running big LTFT say 10% plus it can cause problems. Check for vacuum leaks in intake near maf sensor, check for exhaust leaks near o2 sensors or before o2 sensors.
Scale your MAF sensor. (mass air flow)
Check you IAM (ignition advance multiplier) it should be solid at one. If its less than 1 run better fuel try different brands of fuel or octane booster or change your tune for the lower octane fuel version
more info see links below
Old 08-29-2014, 02:07 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
You can log pedal position and throttle position with oft. Why not take some logs and get an idea where it is lagging. Do you natice it most at high or low rpm? Large or small throttle openings?
1974 TA22 Celica
2013 86 GT
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
Gas pedal tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-22-2012 09:42 AM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
