Old 10-24-2016, 03:57 PM   #1
allowe
allowe's Avatar
Sloppy throttle pedal
There is a half inch dead space in my Accelerator pedal.. is this normal?
I've stalled pulling it out of a parking lot many times. Do frs's just have that or my car is an unlucky one. Also, when it's going like 5-8kms an hour and I put my foot on the gas, it takes a second or 2 before the car starts accelerating.
Any help would be greatly appreciated
allowe is offline   Reply With Quote
Old 10-24-2016, 04:03 PM   #2
It is a drive by wire not a mechanical linked system. Yes there is a bit of a dead zone but you get used to it.
You truly are dead set on finding something wrong aren't you!!!!
Old 10-24-2016, 04:18 PM   #3
funwheeldrive
You could disconnect your battery and let the car relearn the throttle. Is the car stock?
Old 10-24-2016, 04:29 PM   #4
FX86
Is the car stock?
the million dollar question..place your bets fellas
Old 10-24-2016, 04:34 PM   #5
allowe
allowe's Avatar
Lol no it has injen short ram, mxp exhaust.
Old 10-24-2016, 04:36 PM   #6
allowe
allowe's Avatar
Lol! Sorry about my paranoia! The throttle does seem sloppy though.
Old 10-24-2016, 04:38 PM   #7
strat61caster
strat61caster's Avatar
If you don't have a tune odds are it's acting a bit wacky from the intake and reverting back to the OE intake will feel better.
ineedyourdiddly
Old 10-24-2016, 04:48 PM   #8
lantsalot
Derp
lantsalot's Avatar
I've read that a lot of people had sub par performance from just strapping an intake on there and not tuning it, so i'm betting this.
lantsalot is offline   Reply With Quote
Old 10-24-2016, 05:42 PM   #9
VTEC
Drives: Scion FR-S
Agreed with above. Go back to stock intake. That doesn't look normal. If I was blipping my throttle like that you would hear my N1 exhaust rumbling. This car has a very sharp throttle response.
Instagram: @racecar_4life
VTEC is offline   Reply With Quote
Old 10-24-2016, 05:48 PM   #10
funwheeldrive
Agreed, even though the car is drive by wire, throttle response is pretty spot on 99% of the time.
Old 10-24-2016, 05:53 PM   #11
Pretty sure he is just talking about that little bit of travel when you first push it not that he is pushing it and things are not right.
Old 10-24-2016, 05:53 PM   #12
strat61caster
Watched the video again, pretty sure mine totally stock acts the same way from day 1 to now. Throttle just takes a bit more action to get a response vs. a real mechanical throttle.
ineedyourdiddly
Old 10-24-2016, 05:58 PM   #13
Yep. It was the very first thing I noticed when I test drove the car. Wouldn't be surprised to find it was designed in since so little pressure is required. Makes sure you don't accidently rev the crap out of the car just by touching it.
Old 10-25-2016, 02:50 PM   #14
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
That's more than likely your problem. The intake when swapped can cause some bogginess without a tune and have some dead space. Try disconnecting the battery to reset the ECU, it should work, but if not then you might want to go back to the stock intake.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Throttle Pedal Lag gonzo Software Tuning 4 08-29-2014 02:07 AM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
