Old 09-06-2016, 04:17 PM   #1
puma
crew chief
puma's Avatar
Drives: Race car FR-S
For the engine rebuild gurus
OK guys, trying to lift the heads on the FA20 because we are pretty sure we have a blown head gasket. This is my first subaru engine and not much experience engine wise so i am following the shop manual.
I am kind of confused to this portion, i am ready to remove the camshafts but i am not sure this part actually works. So far timing chains are off and from where they let me put the crankshaft and the camshaft, the intake valves on the LH side are open.
Now to remove the camshaft they want me to first turn the cranshaft 200 deg, which in my opinion will make the piston contact the intake valves???
here is the portion i am talking about
After this step, the next step is to turn the camshaft 180deg which i suppose will close the intake valves. Shouldn't i do that before i actually turn the crankshaft? Why in hell are they making me turn the crankshaft before i remove the camshaft?
thanks for any help
puma is offline   Reply With Quote
Old 09-06-2016, 04:30 PM   #2
puma
crew chief
puma's Avatar
Oh and an other question, do i actually have to remove the camshafts gears to remove the camshafts sub assembly or can i leave them installed?
Old 09-06-2016, 08:16 PM   #3
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
You can leave the sprockets attached to the cams. I always just rotate each one a little until there's no tension then remove the caps. Never had an issue. You will know if you have valve contact. Slight movements with no real force
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 09-06-2016, 08:22 PM   #4
puma
crew chief
puma's Avatar
ok makes sense, do you have any idea why they say to do such a thing, i mean rotating the cranshaft before putting the intake valves free of tension?
Old 09-06-2016, 08:41 PM   #5
spitfire481
Drives: 2JZ FRS
No idea. Some of their instructions are confusing and not really needed anyway. Just make sure the head is straight up when you pull the cams out. If not you will loose the rockers and valve shims. Make sure you store them so they go back in the same spot, unless you are replacing valves and or cams
MoTeC
Build Thread
@spitfire481
Old 09-06-2016, 08:50 PM   #6
puma
crew chief
puma's Avatar
wow thanks i was going to remove them like that, i will rotate the engine, thanks for the warning!
Old 09-06-2016, 08:59 PM   #7
spitfire481
Drives: 2JZ FRS
Once the cams come out they will all fall out with ease. Just pay close attention when you lift the cam up. Other than that it's all pretty straight forward. If you're not changing the cams or valves you can reuse the oem shims in there current locations. I'd still double check the clearances during assembly to make sure the factory was right but it should be fine
MoTeC
Build Thread
@spitfire481
Old 09-07-2016, 06:41 AM   #8
puma
crew chief
puma's Avatar
thanks, i appreciate it, i will let you know how it went.
Old 09-07-2016, 11:13 PM   #9
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Do they have any disassembly/assembly books for the fa20 or is it only online
Sent from my SM-G935T using Tapatalk
SoCal80six is offline   Reply With Quote
Old 09-08-2016, 06:33 AM   #10
puma
crew chief
puma's Avatar
i don't know i found mine online, they must have one at the dealer but must cost a fortune and it is he same thing as the online version.
Help Wanted: Wheel Gurus Jyn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 06-18-2014 09:29 PM
Vortech gurus...need your advice misooscar Forced Induction 21 06-04-2014 10:01 AM
Coilver/Suspension Gurus Help!!! eddieEndo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-18-2013 06:57 AM
lighting gurus help needed please FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 11:40 PM
Need help from the wheel fitment gurus nab335 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 10-11-2012 01:39 AM
