Old 06-17-2014, 12:58 PM   #1
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Help Wanted: Wheel Gurus
I have some wheels from my previous car. The problem is that that my last car was stanced more aggressively than what I'd like to do with the FR-S. Currently, the wheels are 18x8.5 +27 front and 18x9.5 +26 rear. Questions I have:
1. Would I be better off rebarreling the wheels and going for a square setup? Maybe something like 18x9.5 +38 or something flush?
2. What are the limitations of rebarreling? i.e. - change the width and offset, or just the offset?
3. The old staggered vs. square setup. I think to keep the handling characteristics of the car, square would be better. But I can't say I wouldn't love as much lip on the wheel as possible
aaand this may be a stretch, but anyone know of any good places near Houston/Austin, TX that can work on wheels? Shipping wheels doesn't sound appealing to me.
Jyn is offline   Reply With Quote
Old 06-17-2014, 02:27 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Questions I have:
1. Goals for the car?
2. Tire size you want to run?
3. What brand wheels are these?
Old 06-17-2014, 02:48 PM   #3
executivekoala
executivekoala's Avatar
Drives: fr-s
I'd just run same tire size. back will have a bit of a stretch but if you do a 245 Federal it should be fine because they run large
executivekoala is offline   Reply With Quote
Old 06-17-2014, 04:17 PM   #4
Jyn
Noob
Jyn's Avatar
Still deciding between air and coilovers, but heavily leaning towards KW V3 with a moderate drop. Want to maintain as much of the stock handling characteristics while still having a good looking car I can bring to shows. I used to show (Wekfest, etc.) with my last car, so I've missed going with the FR-S. But I really have enjoyed driving the Texas country roads with it and want to continue doing that without worrying about rubbing, scraping, bottoming-out, etc.
Nothing too stretched. To make these wheels fit on my last car, I was running 205 front and 215 rear. For the FR-S, doesn't have to be meaty (though that'd be nice), but enough to where I don't get mistaken for hellaflush
Works 3 piece wheel.
Hmm what would I have to rebarrel to get a 245 on there? x9.5 +38?
Old 06-17-2014, 04:21 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No need for a 9.5" unless you want something bigger than a 245. I think a 18x9 +35 with a 235 will probably work well for you if you like a little stretch.
Old 06-17-2014, 04:50 PM   #6
Jyn
Noob
Jyn's Avatar
Ah, ok. I was thinking since I have 9.5, if I rebarrel only one of them it would be cheaper, but then I realized I'd have to rebarrel all of them anyway since the offset is too low on the 9.5
Old 06-17-2014, 04:55 PM   #7
executivekoala
Drives: fr-s
Stop thinking about a re barrel, you do not need it. You can run a 245 on all four and should be okay as long as the tire you use runs big.
Old 06-17-2014, 05:05 PM   #8
Jyn
Noob
Jyn's Avatar
Misunderstood your first post, got it. What profile do you recommend, 245/40? Obviously would need some camber.
Old 06-17-2014, 08:29 PM   #9
executivekoala
Drives: fr-s
Tht really depends on your drop. You should check pics on the wheel fitment with the specs you want, odds are they will have tires mounted. 45 for mild drop
40 for a good drop 35 for aggressive drop
Old 06-17-2014, 08:34 PM   #10
Jyn
Noob
Jyn's Avatar
Yeah, I've been reading the fitment sticky a lot the past few weeks. Probably will go with a 40 profile since I just want a mild drop on some KW v3. Thanks!
Old 06-18-2014, 02:11 AM   #11
executivekoala
Drives: fr-s
There are tire size apps you can download for your phone that really help
Old 06-18-2014, 08:15 AM   #12
diss7
Drives: AE86, 2x GT86, TE27
They'll fit. Rears will come down to what camber you run. If you're like me, and prefer 0.5 or so, then they wont fit.
If I had those wheels, I would run the 9.5's on the front, cos they'll fit with 3deg or so of camber. The 8.5's will fit on the back at 0.5 deg camber.
If you dont care about rear camber, or like to run as much on the back as the front, then you will be able to fit them the normal way.
FYI I'd run 235/40/18 on both.
diss7 is offline   Reply With Quote
Old 06-18-2014, 05:05 PM   #13
Jyn
Noob
Jyn's Avatar
I'll check some out on iOS.
I'd prefer to have the wider wheels on the back and I'm willing to get some LCA if that's what's needed. I don't mind camber, so long as it's not hellaflush levels - not as appealing to me as I've gotten older
Old 06-18-2014, 05:06 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
What I really want to tell you to do is sell those wheels and get a square set in a good offset.
Wanted: Wheel Repair South Bay Cjymiller Northern California 6 05-15-2014 03:29 AM
Coilver/Suspension Gurus Help!!! eddieEndo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-18-2013 06:57 AM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 01:36 AM
lighting gurus help needed please FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 11:40 PM
Need help from the wheel fitment gurus nab335 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 10-11-2012 01:39 AM
