Old 12-04-2013, 10:49 PM   #1
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
Coilver/Suspension Gurus Help!!!
Hi guys, that's the way my car sits now and could use some help and guidance from all you gurus as to what my best available options are when it comes to coilovers/springs/struts. I've also heard some of those 900$ budget coilover options are awful but I wouldn't really know
I do not track my car and have no need for some super racing gnarly coilovers but I do appreciate quality parts and have been doing my best to avoid cheap/low quality parts.
Are Koni Yellows and Rce Yellows a viable option for what I want?? (I've had great experiences with bilstein struts in the past but alas none are available)
Budget: Anywhere below 2000$ (I don't want the absolute cheapest coils on the market, but looking for more of a viable, "most bang for my buck" setup)
What I want out of my suspension:
1. Lower the car about 1-1.5" (Kill some wheelgap, don't want it slammed nor do I want to scrape 4000x a day)
2. To be able to do #1 without sacrificing quality of ride/quality overall of stock suspension
3. Upgraded or at least equal performance to stock setup ( I appreciate the tightness and superb handling of this car and would rather not ruin that quality)
I'm pretty darn satisfied with the wheel/tire setup I am currently running and have no plans of switching (dimension wise)
Wheel/Tire Specs:
FRONT: Rays Engineering Gramlight 57dr 18x8.5 +38 wrapped in Hankook 225/40/18
REAR: Rays Engineering Gramlight 57dr 18x9.5 +38 wrapped in Hankook 255/35/18
eddieEndo is offline   Reply With Quote
Old 12-04-2013, 11:03 PM   #2
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
@CSG Mike @Racecomp Engineering
(just noticed your guys' thread lol)
Old 12-05-2013, 12:57 AM   #3
fatoni
2k and dd screams kw v3
The Following User Says Thank You to fatoni For This Useful Post:
Squishy86 (12-05-2013)
Old 12-05-2013, 02:48 AM   #4
KayC
Drives: 2013 whiteout FRS 6mt
Bilstein B14 PSS coilovers. Quality parts and great set of coils for dd
KayC is offline   Reply With Quote
The Following User Says Thank You to KayC For This Useful Post:
Old 12-05-2013, 04:03 AM   #5
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
I'm running the tein flex and I really enjoy it, after they were corner balanced it made them even more enjoyable.
Build Thread
Instagram
Old 12-05-2013, 09:20 AM   #6
frslee
Just drive it
Drives: 13' FR-S
I would go with Koni + RCE Yellow springs. That combo is confirmed to provide great ride and improved handling. If you're not messing with height, those 32+ adjustable damping, simple and effective setup would be ideal for you..
frslee is offline   Reply With Quote
Old 12-05-2013, 09:43 AM   #7
R/T Tuning
R/T Tuning's Avatar
Drives: 2013 ScionRacing FRS w/2AZ-FE swap
A'pexi N1 Coilvoers are a nice option for a DD. And a great bang for buck...they list our for $1290 and come with new end links too... i have one set left from my black friday blowout for $900 shipped if interested.
R/T Tuning is offline   Reply With Quote
Old 12-05-2013, 09:58 AM   #8
djdnz
1337
Drives: 2013 BRZ WRB S/C
I got the RCE Tarmac Zero coilovers. They are pretty nice, though I would recommend looking into the KW V1, and if you are not in a salty/winter climate go for the ST coilovers. They're all based on the KW V1, very similar.
You don't get adjustable camber plates but honestly for a DD it's not necessary. I'd also recommend getting LCA's to adjust the rear camber (I got the new SPC's, they were great!). Front you don't need because the KW's have slotted holes to allow for modest camber adjustment.
Overall I think this setup will cost you in the range of 1500+ alignment (or less with the ST's) and you will be very happy with the outcome for a DD.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
eddieEndo (12-05-2013)
Old 12-05-2013, 10:53 AM   #9
The Koni Yellow + RCE Yellow set-up is really good. Definitely a set it and forget it, don't worry about it and have fun driving system. Easy to drive and fast. Mild but noticeable 20mm drop that looks good. The Konis have pretty good valving and are adjustable.
RCE Tarmac 0 (or KW V1) would be good if you want to go slightly lower. A little firmer than the Koni set-up but at least with the RCE T0 it's a bit faster. Still good ride quality.
The Bilstein coilovers are tempting but I have not tried them yet. Myles in the office has some experience.
Either way, no need for camber plates for you and honestly I'd avoid them. Rear LCAs would be a good addition though.
$2k for KW V3 would be tempting, but I'd rather Tarmac 0 for less than spend the rest on LCAs and bushings to round out the package.
Feel free to give us a call or PM to chat!
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 12-07-2013, 02:12 AM   #10
TheLaughingMan
TheLaughingMan's Avatar
@eddieEndo
let me know what you end up going with as it sounds like your goal is about the same as mine
TheLaughingMan is offline   Reply With Quote
Old 12-07-2013, 03:41 PM   #11
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
Originally Posted by TheLaughingMan View Post
@eddieEndo
will definitely keep you updated, gonna work my ass off this week to get them probably
Old 12-08-2013, 02:27 AM   #12
Trmx2
Trmx2's Avatar
Drives: 2014 Raven FR-S 6spd
@eddieEndo
+1 to this, OP sounds just like me. I've been racking my brain with all the mods out there. I'm trying to decipher the difference between strategic marketing vs. proven performance.
I currently have ZERO mods on my frs....I'm dying to do something to it!
Trmx2 is offline   Reply With Quote
The Following User Says Thank You to Trmx2 For This Useful Post:
eddieEndo (12-08-2013)
Old 12-08-2013, 02:55 AM   #13
TheLaughingMan
Not only that but I don't intend to have my FR-S as a racecar or even track/autox that often. I just want the lowering with adjustability (for finding an acceptable ride hide with aerokits and roads around here), and suspension that is as good or better than the car's stock suspension for spirited driving.
I have tried to read about spring rates, motion ratios, etc. and usually it ends up getting too complicated too fast Even the stickied thread on here, "Basic tech info: spring rates, rear suspension, motion ratios, and you." was a little hard to follow. I think I need a "Aftermarket Suspension for Dummies" with illustrations
So far from what I've read the KW V1 coilovers seem to be the way to go for me. I'm know for a fact that I'm going to have a professional install and adjust them.
The Following User Says Thank You to TheLaughingMan For This Useful Post:
Old 12-08-2013, 04:08 AM   #14
Trmx2
Trmx2's Avatar
PMed you, and I totally agree with what you're saying. It's all in my PM lol
EcuTek Gurus - questions about RaceRom feature maps RehabJeff86 Software Tuning 8 09-09-2013 02:22 PM
On lowering springs now and a final dilemma, suspension gurus reply please.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-12-2013 10:06 AM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
lighting gurus help needed please FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 11:40 PM
Need help from the wheel fitment gurus nab335 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 10-11-2012 01:39 AM
