Old 05-29-2014, 01:00 AM   #1
misooscar
misooscar's Avatar
Drives:
Vortech gurus...need your advice
Here's my setup
550 fbm injectors and 270 L/hr fuel pump (fbm) fuel pump
Vortech v2 (oil fed)
Perrin oil cooler
E85 tune
I am aiming for 300-350 whp
2.6" full exhaust
What Pulley should I run and what psi would I be at to hit the target hp?
Thank you in advance
Sent from my SM-N900T using Tapatalk
misooscar is offline   Reply With Quote
Old 05-29-2014, 09:09 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@nelsmar @draggin_az
The Following User Says Thank You to Sportsguy83 For This Useful Post:
misooscar (06-03-2014)
Old 05-29-2014, 09:33 AM   #3
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
is e85 an option for you?
Depending on that is what your end whp goal is going to be.
I have a full FAQ on everything Vortech if you need some other info too.
http://www.ft86club.com/forums/showthread.php?t=66430
marcoaferrer is offline   Reply With Quote
The Following User Says Thank You to marcoaferrer For This Useful Post:
Old 05-29-2014, 09:36 AM   #4
marcoaferrer
And what headers where you considering? If possible try to get a set of EL headers with larger primaries. Those type of headers really compliment the vortech setup.
Check out this thread.
http://www.ft86club.com/forums/showt...hlight=vortech
These were custom headers built for this car in the style I mentioned above. This specific header you cant get since there was only one made nor would I recommend buying anything from the FA20Crap brand. But Im sure you could get a custom set made or at least something really close.
Old 05-29-2014, 09:45 AM   #5
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
For your setup 300 Dynojet whp is relatively easy, even on pump gas.
You could do a 3" pulley, or a wastegate setup on a smaller pulley for those goals.
2.87" on e85 = 382whp for my car on the v3 blower.. and potentially 400+ with the right tune.
With 2.62" the limits haven't been explored much. 450+?? who knows. Building the engine would make a lot of sense.
You have a good clutch and cooling mods? Also the widest stickiest tires that fit because the wheelspin is pretty silly.
jack43 is offline   Reply With Quote
The Following User Says Thank You to jack43 For This Useful Post:
Old 05-29-2014, 09:46 AM   #6
jack43
jack43's Avatar
Old 05-29-2014, 09:47 AM   #7
jack43
jack43's Avatar
[quote=jack43;1765812]
A header only makes <5hp with a SC in my experience. I had a JDL and took it off.
Old 05-29-2014, 09:54 AM   #8
marcoaferrer
@jack43 Ive been watching your build and it is NICEEEE. lol
As far as my header commment Im basing it off of the result of that custom fa20club header in the thread i linked and what most guys on other platforms do to increase power out put on vortech set up (mustangs,g35,350z,s2000) Dont flame me I KNOW those are totally different cars but thats what those vortech guys recommend to each other. NA fa20 headers wont make as much of a difference as a header custom made for a supercharger application. Even jdl said that they might make a sc specific header for this platform with larger primaries.
jack43 (05-29-2014)
Old 05-29-2014, 09:59 AM   #9
marcoaferrer
also the 2.62 pulley spins the blower over 55k rpm which is past what the blower is built to flow at. You may loose power because youll be operating wayyyy outside of the blowers efficiency range. just check out the compressor map and youll see the 55k rpm cap. If you REALLY wanted to spin the blower at its max rpm youll need a 2.75 pulley. but in my opinion its nots really worth it. plus so far the 2.75 pulley is only available in 8rib config. (atleast i havent found a 6 rib config yet.)
Old 05-29-2014, 10:35 AM   #10
jack43
jack43's Avatar
OP has the v2 so he's good to go on the 2.62"
Old 05-29-2014, 10:39 AM   #11
marcoaferrer
the v2 doesnt have an unlimted rpm (even though thats not how brians been marketing it on the forums). the impeller is still the same. It may be able to spin faster than the 52k rpm limit of the v3 it is still bound to what the impeller can perform at which is at max 55k.
faster isnt always better. same concept applies on turbo. upping the boost wont always make more power.
draggin_az (05-29-2014)
Old 05-29-2014, 11:56 AM   #12
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
you'll get 300 on E85
i had the V3, stock pulley, stock injectors and stock fuel pump and put down 260 with the pump maxed out. we installed a new pump and squeezed some more hp out of but maxed out the injectors.
i put in the 2.87 pulley and 770cc at the same time and had a retune. the power difference was amazing. i would say close to 300 on pump gas and the tune wasnt complete yet. i was logging and updating with the tuner and a seal gave out.
382....very nice.
after i get my blower back (its being rebuilt and converted to a v2) and the 93 tune is dialed in, i'll start working on E5. i have the kit, just gotta get my car back on the road and get the 93 tune dailed in.
stay away from fa20club anything. he was good for a little bit then his quality in parts and customer service went waaaaaaaay down hill.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 05-29-2014, 11:58 AM   #13
marcoaferrer
lmao you dont have to tell me. I was just showing an example of what a custom header can do.
Old 05-29-2014, 12:09 PM   #14
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
not sure how its been on these motors but the 2.62 pulley i ran on my vortech supercharged gti had a ton of belt slip issues. even with a ton of tension, good belt wrap, and a gates green stripe belt. just something to think about when going down pulley sizes
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
marcoaferrer (05-29-2014), misooscar (06-03-2014)
Coilver/Suspension Gurus Help!!! eddieEndo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-18-2013 06:57 AM
EcuTek Gurus - questions about RaceRom feature maps RehabJeff86 Software Tuning 8 09-09-2013 02:22 PM
On lowering springs now and a final dilemma, suspension gurus reply please.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-12-2013 10:06 AM
lighting gurus help needed please FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 11:40 PM
Need help from the wheel fitment gurus nab335 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 10-11-2012 01:39 AM
