Old 08-16-2016, 04:37 PM   #1
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Question Would this work to turn off the p0420?
Deleting the primary cat produces a lot of power and deleting the secondary cat produces very little but can cut down on some of the noise of running an open header. Obviously, you need some sort of tuning solution. But of course, deleting the the primary cat throws a p0420 code.
Would this work- deleting the cat in the header and using a Subaru o2 sensor extension harness to move the o2 sensor to a new bung behind the secondary [intact] cat to make the p0420 monitor happy? The existing second o2 bung can be plugged. Would this work to make the power of a catless header but keep the p0420 code from popping up?
Old 08-16-2016, 04:39 PM   #2
guybo
Huge E85 fan!
guybo's Avatar
This would be for a setup with no ECU reflash so there's no way to turn off the 420 with software alone.
Don't say just get a reflash, this is about doing this some way other than flash or o2 spacer
Old 08-16-2016, 04:39 PM   #3
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Let me think......all this without a tune........OFT tunes for header have the code disabled......naw couldn't work, or will it.....................
IceFyre13th is offline   Reply With Quote
Old 08-16-2016, 04:46 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Unichip can not turn off codes. I'm thinking out of the box
Old 08-16-2016, 04:51 PM   #5
Teseo
Drives: frs
Cut a little duct tape and put where on the CEL bright?
Old 08-16-2016, 04:53 PM   #6
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
You would have to run both O2 sensors in the correct order via wiring. The code is saying that the cat is or isn't doing its job by comparing readings from the two sensors on either side of a cat. You would need an extention long enough to move the second sensor to behind the 2nd cat.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Respect BRZ is offline   Reply With Quote
Old 08-16-2016, 04:56 PM   #7
bababooey
Drives: BRZ SWP Limited -6MT
haha, did exactly that cause a.m. wheels with no tpms
Old 08-16-2016, 05:00 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
I've run with the CEL on with other cars and didn't care, but this car turns off the cruise control when the CEL is on so it has to be off (if I have to manually turn it off occasionally with Torque Pro that's ok but not every day).
I'm thinking of keeping the first o2 sensor in place. I'll plug my wideband a/f gauge into the existing second bung and have a bung welded into place AFTER the secondary cat and plug the second cat into the new bung. The order would be unchanged, just the placement of the second o2 sensor would change.
Old 08-16-2016, 05:11 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
In theory it could work, but you are assuming similar efficiency.
FWIW, the Apex'i setup relocates the secondary O2 sensor behind the cat, and it threw no CEL.
In the front there's a primary O2 sensor bung, as well as one for wideband O2 sensor.
-alex
Old 08-16-2016, 05:34 PM   #10
guybo
Huge E85 fan!
guybo's Avatar
The efficiency thing is what makes me think this wont work. The second cat just isn't as good at scrubbing the exhaust. The Apexi setup gives me hope it may work.
This is 100% theoretical since doing this would be illegal. Just so everyone knows...
Old 08-16-2016, 08:15 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Imho it's just reduced chances to throw CEL just as with "normal" catted aftermarket headers, but no 100% guaranteed CEL elimination.
But i like the idea of adding O2 bung to frontpipe after 2ndary cat to connect sensor with extension cable there. Makes a bit more sense then O2 spacers. As i wanted in future some good catless header + stock catted pipe, considering adding sensor bung to it in similar way.
Old 08-16-2016, 08:28 PM   #12
Cole
Not a troll
Cole's Avatar
Or you could just get a proper tune and throw the unichip in the trash, since that's where it belongs.
Old 08-16-2016, 10:23 PM   #13
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
It's a narrow band sensor. The efficiency is not really relevant.
The short answer is yes, relocating the post-catalyst sensor will work.
@Cole, that is sage advice. That unichip does indeed belong in the trash.
What if I told you... Nothing is Illegal...
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 08-16-2016, 10:42 PM   #14
ryoma
ryoma's Avatar
it's only illegal if you get caught
(joke btw pls don't flame me)
P0420 Code... Need help R3b00T Engine, Exhaust, Transmission 4 07-11-2016 04:18 PM
P0420 & ECUTek SpectreRT Engine, Exhaust, Transmission 7 06-13-2016 03:27 PM
Work Bell 10021 U-Turn Harness Male Connector - No Air bag light Resistor! Jeeper_x Interior Parts (Incl. Lighting) 5 01-04-2015 04:45 PM
p0420 brichard0625 Issues | Warranty | Recalls / TSB 11 08-04-2013 09:24 PM
Help! Headlights/turn signals don't work and I can't get my car out of park Cajun Cosmetic Modification (Interior/Exterior/Lighting) 27 01-11-2013 11:02 AM
