Old 08-02-2013, 05:49 PM   #1
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
p0420
For the longest time now i have had the p0420 code. Took to toyota many times and still no solution for it. Anybody else have this issue? anybody have any recommendations on what to check?
brichard0625 is offline   Reply With Quote
Old 08-02-2013, 06:56 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Did you search? Any mods on your exhaust/header?
A search for p0420 yields a ton of threads about headers and CELs.
-alex
Old 08-02-2013, 09:47 PM   #3
brichard0625
i had this code way before i even had mods on my car. Just wondering if anybody with this car has had this code before stock?
Old 08-02-2013, 09:55 PM   #4
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
bad 02 sensor?
Old 08-02-2013, 09:56 PM   #5
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
or bad cat
Old 08-02-2013, 09:56 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
http://www.obd-codes.com/p0420
Old 08-02-2013, 10:34 PM   #7
brichard0625
checked the o2 sensors and not sure how to check the cat but if its is the cat then i need a whole new header im guessing...it cant be the 2nd cat because now i deleted it and im still getting 420 code
Old 08-02-2013, 10:38 PM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
420 is not a bad code at all.
Why not get u ecutek license again and tell John to disable that code
Old 08-04-2013, 12:02 PM   #9
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
if the sensor is fine i wouldnt worry b/c that jus means its the cat. so ur jus not as eco friendly, but if ur modding the car and changing even a catback then i doubt ur an econut anyways. other then the light being annoying its nothing. id b more worried about ur seatbelt light on if u werent wearing it lol
lbroskee is offline   Reply With Quote
Old 08-04-2013, 01:16 PM   #10
pche
Guy on internet
Drives: Slowly
How did you check the sensor exactly? The secondary cat is not monitored so it wouldn't throw a P0420. If you're using stock exhaust manifold the dealer should cover it under warranty.
pche is offline   Reply With Quote
Old 08-04-2013, 01:22 PM   #11
Phothiraj
Drives: Lightning Red BRZ
p0420 is a bad cat. you should get that checked out. might have a leak or something.
Phothiraj is offline   Reply With Quote
Old 08-04-2013, 09:24 PM   #12
brichard0625
i had my mechanic check the plugs for me and he said they were fine...we checked for leaks and there was no leaks..when i took it to toyota they had checked everything out as well and could not determine the problem..when i clear the codes it takes a while for it to come back on so everytime they think they have fixed it ends up coming right back on. Im just going to tell them to change the plugs anyway and see if that clears the code.
