Old 01-07-2013, 02:21 PM   #1
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
Help! Headlights/turn signals don't work and I can't get my car out of park
I just installed the relay for led turn signals. When I pulled out the old relay, it snapped in half. Now my "bright lights are on" light is lit up on my instrument panel. My headlights and turn signals do not work (front or rear). Rear lights and side markers work. The new turn signals light up, but they dont blink. instrument panel doesnt show blinkers when attempting. When I turn my car off, with the lights in the "off" position, my car beeps, telling me that my lights are on. Now my car wont get out of park!!! Help!!! Seller said i may have blown a fuse, what exactly do I need to do?? i have no clue!! Now car is off, keys are out, and my side markers and rear tail lights are still on, but lights are set to "off"
Cajun is offline   Reply With Quote
Old 01-07-2013, 02:23 PM   #2
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
I had this exact same thing happen. I assume you didn't disconnect the battery when you tried installing your relay? You just blew a fuse.
i_4got is offline   Reply With Quote
Old 01-07-2013, 02:25 PM   #3
Cajun
Cajun's Avatar
Ok good- sounds simple. Which fuse?? Any idea
Old 01-07-2013, 02:27 PM   #4
i_4got
i_4got's Avatar
Sorry, don't remember which one. I didn't know what was going on, and panicked so I called Scion roadside assistance. They replaced the fuse for me under warranty, though I probably could have done it myself if I knew exactly what was wrong.
Old 01-07-2013, 02:30 PM   #5
Cajun
Cajun's Avatar
Did u have all the same "symptoms" as me??
Old 01-07-2013, 02:33 PM   #6
i_4got
i_4got's Avatar
Yup, everything was exactly the same. My instruments panel lit up and wouldn't turn off, the turn signals stayed on but wouldn't blink, side markers and rear lights stayed on. I couldn't turn any of these lights off, and I couldn't get my car out of "park".
This also happened to me when I tried to install my new relay, but forgot to disconnect the battery first.
Old 01-07-2013, 02:42 PM   #7
Cajun
Cajun's Avatar
My dad is on the way to fix this. Guess that's why they say women should stay in the kitchen! I hope once the fuse is replaced, everything is back to normal
Old 01-07-2013, 03:14 PM   #8
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
you're a girl? and you're playing with the wiring?
chenshuo is offline   Reply With Quote
Old 01-07-2013, 03:17 PM   #9
Cajun
Cajun's Avatar
Lol well it looked so simple! I didn't know to disconnect the battery.
Old 01-07-2013, 03:17 PM   #10
Cajun
Cajun's Avatar
But you should be proud that I at least tried!!!
Old 01-07-2013, 03:18 PM   #11
Cajun
Cajun's Avatar
Oh and I'm gay, which gives me even more reason to try this myself! Lol
Old 01-07-2013, 03:19 PM   #12
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Ok...why did you pull the relay when you had power on/key turned in the first place? I did not disconnect my battery when I did it, I just did not have the key in - simple. Also how did you break it? Gentle!
Old 01-07-2013, 03:21 PM   #13
Cajun
Cajun's Avatar
I didn't have the key in when I pulled out/ changed the relay.
Old 01-07-2013, 03:22 PM   #14
Cajun
Cajun's Avatar
I put my key in once the lights and relay were installed
DIY JWMotoring LED turn signals sirhc DIY (Do-It-Yourself) Guides 54 03-16-2013 03:22 PM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
Simple One: Clear Turn Signals Spaceywilly Cosmetic Modification (Interior/Exterior/Lighting) 37 07-26-2012 02:03 AM
