Old 07-11-2016, 03:43 PM   #1
R3b00T
R3b00T's Avatar
Drives: 2015 BRZ (white)
P0420 Code... Need help
4 weeks ago, got a shop that installed for me a mxp headers,overpipe and catback. Now this P0420 code appeared. I dont want to go the dealership coz for sure they will void my warranty.... Need help!
R3b00T is offline   Reply With Quote
Old 07-11-2016, 03:45 PM   #2
gramicci101
Off Topic
Did you get a tune? Every stage 2 flash turns that off, and any custom tune should do so as well, as long as the tuner remembers to do it.
If you didn't get a tune with a catless header then A. you'll pop a code, and 2) you're missing out on a lot of power.
Old 07-11-2016, 04:12 PM   #3
R3b00T
R3b00T's Avatar
Im scheduled on the 26th for a tune up.... Im glad to know it will fix it... For now i was able to clear the light by resetting it..
Thank you!
Old 07-11-2016, 04:15 PM   #4
gramicci101
Off Topic
Thank you!
By "tune up" do you mean dyno/ECU tune? If so, then yes, that will fix it.
The light is a catalytic converter efficiency light. It measures both before and after the cat in the header. Since you've removed the cat from the header, the light will keep coming back until you get the car tuned.
Old 07-11-2016, 04:18 PM   #5
R3b00T
R3b00T's Avatar
Yes, ecu tune up..... So much knowledgeable members here...
Ty for your inputs sir!
Catless UEL + Tune...Still Get P0420 Michael Engine, Exhaust, Transmission 18 07-19-2016 04:33 PM
P0420 & ECUTek SpectreRT Engine, Exhaust, Transmission 7 06-13-2016 03:27 PM
Code p0420 Patsully3 Issues | Warranty | Recalls / TSB 17 02-26-2016 10:45 PM
OFT Disable P0420 Cat Efficiencty livingambition Software Tuning 2 06-18-2015 09:18 PM
p0420 brichard0625 Issues | Warranty | Recalls / TSB 11 08-04-2013 09:24 PM
