Drives: Whiteout FRS, 07 Stg 2 Vw GTI
Initial Impressions of the Trackspec T1 Hood Louvers
Hey guys, I just installed the Trackspec T1 Hood Louvers. Although I haven't driven it much since I just installed it, I'd like to give my initial impressions and move on to a more in depth review later on.
A little background about my car. It's a turbo track car which I've spent quite a bit of time trying to make everything run correctly. Latest issue has been cooling. I'm using a Mishimoto oil cooler, thermostat (just keep it stock), and Mishimoto slim fans (don't get these either), and Koyorad radiator. Opted for the slim fans because the oem fan shroud was melting due to the turbo being so close and hot. At the last event at Shenandoah, my p3 gauge showed coolant temps hit 245 before going into limp mode until the temps came down. Ambient air temperature was between 85-88 degrees. The amount of hot air trapped under the hood after coming off track was immense. The hood release latch was burning hot to the touch. Now onto the actual review, I received the box in good condition. There was plenty of bubble wrap and packing material. They supply you with a template and all rivets and washers you'll need with detailed instructions. The installation was straightforward. ![]() ![]() The quality of the vents are top notch. They sit nicely flush against the hood without any gaps in between. My coolant temps at highway speeds dropped between 10-20 degrees and temps come down much faster after idling and start moving again. It's also pretty cool to see the hot air come out of the vents including more choo choo noises from the engine bay. More testing will be done soon and updated accordingly. Highway temps Before: 200-220 After:190 ![]() ![]() ![]() ![]()
| The Following 2 Users Say Thank You to Andrew360 For This Useful Post: | CounterSpace Garage (08-05-2016), Jonsey (08-05-2016) |
Any thoughts on the structural impact of running these?
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Drives: Subaru BRZ / Toyota 86 Experts
It sounds counterintuitive cutting structural ribbing out of the hood and adding these vents. It's quite the contrary. Those who have installed it have had no issues with the hood flexing. In effect, they have noted that the hood flexes less and also found that the hood does close tightly to the engine bay due to the high pressure differential at speed. Track guys with good pace will note that the OEM hood (even those non-functional vented hoods) actually wobbles (and slightly bulges open) on the track or in a high speed section. That issue is nonexistent with the Trackspec Louver Kit.
| The Following 5 Users Say Thank You to CounterSpace Garage For This Useful Post: | Clutch Dog (08-10-2019), funwheeldrive (08-07-2016), Tristor (08-12-2019), whataboutbob (06-21-2018), zdr93523 (08-08-2016) |
#5 | |
Sent from my SM-N910T using Tapatalk |
#6 | |
I believe the vents, technically, add more material than is removed. AFAIK the vents are not a weight reduction either, but the additional cooling and pressure reduction is absolutely worth it.
#8 | |
Drives: the white one
I was considering adding the thermostat because I tend to cruise around town in the FRS every now and again. I was worried about the oil cooler making the oil TOO cold(if its even possible). Cold enough to be out of operating temperature. Thoughts?
If you can't win a race, beat the person in front of you
Drives: Velocity Orange 86 GT
We have had guys here without them. In the summer (30C they live in colder climates) they would get the oil to 70C on the highway. Arguably high enough to drive in most conditions but perhaps not perfect. Of course heat up is slower too. In the winter it was to cold for comfort for sure. For me with 50C ambient temps for most of the year it doesn't make much difference at all.
#10 |
Drives: 2013 Subaru BRZ Limited (WRB)
Add a thermostat for the oil line and you'll be fine. I've been running the Jackson Racing Oil Cooler for a while now (comes with the thermostat sandwich plate that installs below oil filter) and it gets far below 0F in Iowa during the winters. Car warms up fast enough and the thermostat regulates it to 185F'ish.
#11 | |
Drives: 2013 BRZ Limited
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
| The Following User Says Thank You to zdr93523 For This Useful Post: | CSG Mike (08-09-2016) |
#12 | |
#13 | |
Drives: Track preped NA FRS
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | CSG Mike (08-09-2016) |
#14 |
The thermostatic plate always allows a small amount of oil through to avoid creating an air lock in the cooler core. It is always possible that the oil wouldn't be heating up above 185F even without the cooler in some conditions, so seeing it below 185F shouldn't be a huge concern.
| TrackSpec Hood Louvers | CounterSpace Garage | Tracking / Autocross / HPDE / Drifting | 55 | 12-29-2017 09:21 AM |
| TrackSpec Hood Louvers | CounterSpace Garage | Forced Induction | 75 | 02-21-2017 08:09 PM |
| TrackSpec Hood Louvers | CounterSpace Garage | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 07-27-2016 06:41 AM |
