Old 08-05-2016, 02:57 PM   #1
Andrew360
Andrew360's Avatar
Drives: Whiteout FRS, 07 Stg 2 Vw GTI
Initial Impressions of the Trackspec T1 Hood Louvers
Hey guys, I just installed the Trackspec T1 Hood Louvers. Although I haven't driven it much since I just installed it, I'd like to give my initial impressions and move on to a more in depth review later on.
A little background about my car. It's a turbo track car which I've spent quite a bit of time trying to make everything run correctly. Latest issue has been cooling. I'm using a Mishimoto oil cooler, thermostat (just keep it stock), and Mishimoto slim fans (don't get these either), and Koyorad radiator. Opted for the slim fans because the oem fan shroud was melting due to the turbo being so close and hot.
At the last event at Shenandoah, my p3 gauge showed coolant temps hit 245 before going into limp mode until the temps came down. Ambient air temperature was between 85-88 degrees. The amount of hot air trapped under the hood after coming off track was immense. The hood release latch was burning hot to the touch.
Now onto the actual review, I received the box in good condition. There was plenty of bubble wrap and packing material. They supply you with a template and all rivets and washers you'll need with detailed instructions. The installation was straightforward.
The quality of the vents are top notch. They sit nicely flush against the hood without any gaps in between. My coolant temps at highway speeds dropped between 10-20 degrees and temps come down much faster after idling and start moving again. It's also pretty cool to see the hot air come out of the vents including more choo choo noises from the engine bay. More testing will be done soon and updated accordingly.
Highway temps
Before: 200-220
After:190
Andrew360 is offline   Reply With Quote
The Following 2 Users Say Thank You to Andrew360 For This Useful Post:
CounterSpace Garage (08-05-2016), Jonsey (08-05-2016)
Old 08-05-2016, 03:19 PM   #2
Jonsey
Jonsey's Avatar
Any thoughts on the structural impact of running these?
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 08-05-2016, 03:29 PM   #3
Andrew360
Andrew360's Avatar
These do not reduce the structural integrity. There wasn't any additional flex in the hood after the vents were installed. Maybe @counterspacegarage can chime in.
Old 08-05-2016, 04:32 PM   #4
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
It sounds counterintuitive cutting structural ribbing out of the hood and adding these vents. It's quite the contrary. Those who have installed it have had no issues with the hood flexing. In effect, they have noted that the hood flexes less and also found that the hood does close tightly to the engine bay due to the high pressure differential at speed. Track guys with good pace will note that the OEM hood (even those non-functional vented hoods) actually wobbles (and slightly bulges open) on the track or in a high speed section. That issue is nonexistent with the Trackspec Louver Kit.
CounterSpace Garage is offline   Reply With Quote
The Following 5 Users Say Thank You to CounterSpace Garage For This Useful Post:
Clutch Dog (08-10-2019), funwheeldrive (08-07-2016), Tristor (08-12-2019), whataboutbob (06-21-2018), zdr93523 (08-08-2016)
Old 08-05-2016, 04:41 PM   #5
Andrew360
Andrew360's Avatar
Couldn't have said it better myself. I'll be at NJMP Lightning tomorrow to test it out.
Sent from my SM-N910T using Tapatalk
Old 08-05-2016, 05:49 PM   #6
Jonsey
Jonsey's Avatar
That's what I assumed. The vents appear to have a strong structural ring that would strengthen the opening and tie the ribbing together.
Old 08-05-2016, 07:37 PM   #7
CSG Mike
CSG Mike's Avatar
I believe the vents, technically, add more material than is removed. AFAIK the vents are not a weight reduction either, but the additional cooling and pressure reduction is absolutely worth it.
Old 08-05-2016, 09:47 PM   #8
CrispyCheddar
CrispyCheddar's Avatar
Drives: the white one
I have the mishi oil cooler, but haven't installed it yet.
I was considering adding the thermostat because I tend to cruise around town in the FRS every now and again. I was worried about the oil cooler making the oil TOO cold(if its even possible). Cold enough to be out of operating temperature.
Thoughts?
If you can't win a race, beat the person in front of you
CrispyCheddar is offline   Reply With Quote
Old 08-06-2016, 07:18 AM   #9
Northwest86
Drives: Velocity Orange 86 GT
Thoughts?
We have had guys here without them. In the summer (30C they live in colder climates) they would get the oil to 70C on the highway. Arguably high enough to drive in most conditions but perhaps not perfect. Of course heat up is slower too. In the winter it was to cold for comfort for sure. For me with 50C ambient temps for most of the year it doesn't make much difference at all.
Northwest86 is offline   Reply With Quote
Old 08-07-2016, 12:25 AM   #10
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Add a thermostat for the oil line and you'll be fine. I've been running the Jackson Racing Oil Cooler for a while now (comes with the thermostat sandwich plate that installs below oil filter) and it gets far below 0F in Iowa during the winters. Car warms up fast enough and the thermostat regulates it to 185F'ish.
Apex_BRZ is offline   Reply With Quote
Old 08-08-2016, 09:51 PM   #11
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I can corroborate this 100%.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
The Following User Says Thank You to zdr93523 For This Useful Post:
CSG Mike (08-09-2016)
Old 08-08-2016, 09:55 PM   #12
Andrew360
Andrew360's Avatar
Thoughts?
I have the mishimoto thermostatic oil cooler. Not sure if the thermostat is defective or some oil just leaks thru but my oil temps only goes up to around 165-170F at highway speeds in cooler weather. 50-60F days. The thermostat is supposed to regulate it to 185F.
Old 08-09-2016, 12:18 AM   #13
Icecreamtruk
Drives: Track preped NA FRS
I cant really monitor mine (closed when tuned by ecutek if trying to log with torque), but I did read somewhere in this forum that even when "fully" closed, some oil will still flow thru it. I have been thru 1 canadian winter (below 0 way too often) and over 10 track days after that winter without trouble, I dont think the temps are low enough to affect the engine (unless your normal driving involves redlining on every light).
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Old 08-09-2016, 08:50 AM   #14
wparsons
wparsons's Avatar
The thermostatic plate always allows a small amount of oil through to avoid creating an air lock in the cooler core. It is always possible that the oil wouldn't be heating up above 185F even without the cooler in some conditions, so seeing it below 185F shouldn't be a huge concern.
flickr
TrackSpec Hood Louvers CounterSpace Garage Tracking / Autocross / HPDE / Drifting 55 12-29-2017 09:21 AM
TrackSpec Hood Louvers CounterSpace Garage Forced Induction 75 02-21-2017 08:09 PM
TrackSpec Hood Louvers CounterSpace Garage Cosmetic Modification (Interior/Exterior/Lighting) 15 07-27-2016 06:41 AM
