Drives: Subaru BRZ / Toyota 86 Experts
TrackSpec Hood Louvers
One of the major challenges with the FT86, is the ability to extract heat out of the engine bay. While a stock car that is street driven doesn't have any problems staying within normal operating temperatures, cars that are Forced Induction, or are driven hard on the track often have overheating issues.
Another occurrence the more spirited drivers may have noticed, is that the stock hood "flaps" at higher speeds. There is a lot of air trapped under the hood, and to escape, the air wobbles the stock hood, escaping out the side. This produces a few undesirable effects: extra drag, front end lift, and a general feeling of uneasyness about the hood staying in place. CSG is proud to introduce the TrackSpec Motorsports Hood Louver/Heat Extractor Vents for the FRS/BRZ/GT86. A major design hurdle was finding a proper model of the FRS/BRZ/GT86 to perform CFD analysis to determine the effectiveness of the hood. Such analysis is often performed, but CSG and TrackSpec discovered that all of the commonly available models had some major flaws: they all assume a flat underbody, and they do not model inside the engine bay at all! With such a flawed model, the analysis would also be heavily flawed, so we set about seeking to make our own model. Unfortunately, with the budget we have, it was impossible to laser scan such a complex shape (the underbody, and more importantly, the engine bay) to get the level of accuracy we sought. This led us to use the flawed models, with some modifications, to attempt to simulate airflow through the engine bay. This data, being flawed, was taken with a grain of salt, and was used only to try different shapes, angles, and sizes of vents, which would ultimately be verified with real world testing. Due to the complexity of the actual car, real world testing would be the only feasible way to get accurate measurements (we don't have the budget for windtunnel testing... sorry!). The end result of this testing, is the vent pictured below. The vent is designed to drop into the stock hood, and does several things: - an overall 43% drop in under-hood pressure at highway speeds - a 60% drop in under-hood pressure at 120mph! - A net front downforce (we had to add wing angle during testing to balance the now-grippier front) - Increased cooling (less pressure under the hood = more air flowing through the radiator; more air being extracted = more air flowing through the radiator) The above claims were verified with real-world data, and tested at Willow Springs Intentional Raceway, aka "The Fastest in the West" at speeds up to 130mph under race conditions. MSRP is $329.99, and are now available at http://counterspacegarage.com/produc...-frs-gt86.html ![]() ![]() ![]() ![]() ![]() ![]()
Drives: 2018 BRZ tS
Let the battle of the hood louvers begin! Jk, nice design, flows really well with the hood. Any pictures if the underside, and does the oem support need to be moddified to allow for install?
Custom User Title
Drives: Asphalt FR-S MT
So we have two new options for vents for our hoods. So how exactly do they compare?
Do you have any underside pics? What are they made of? Is there any consideration to rain and other weathering? How are they finished?
#4 | |
The vents are Aluminum, and powdercoated satin black. Covers are being designed, due to popular demand, but at the moment, no. The engine bay would be exposed, the same as any other vented/louvered hood . |
Strange. I could have sworn I posted underside pictures.
Covers are in the works, but some other projects are being finished that are in queue first (Mustang testing, Camaro testing). |
Drives: Subaru BRZ
So I installed mine today and I've got to say is was really easy all things considered. Just gotta make sure you measure twice cut once, and with the templates they provide, it's pretty easy.
I decided to go with a different layout of the install with mine and I'm pretty happy with the way it came out. Clears the Edelbrock SC with ease.
Supra Senior Member
Drives: AE86 & BRZ
[/QUOTE]I just want to tag you so you post more pix and bump the post please and thank you.
Drives: 2JZ FRS
Installed a set today on a customers road race Frs. Went very smooth. Thinking about doing a set on my drag car to help keep heat down
#10 |
Drives: 2016 Blackout BR86
Any progress on those covers? Interested in purchasing a set except my car doubles as a daily driver that sits outside.
#11 |
Drives: '13 LAVA - lightly modded
Would louvers actually be a problem for DD? What's the difference between washing under your hood and having rain and such get in there? I've heard people voice these concerns but don't know why specifically it is a problem
You are going to be condemned to live out the consequences of your taste - TM
#12 | |
Drives: Asphalt 2013 FR-S
Build Thread: http://www.ft86club.com/forums/showthread.php?t=87104 // Save the fenders
#13 |
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I'm waiting for the covers to come out.
![]() Question: Is there any concerns with structural rigidity of the hood with the cutting out significant portion of reinforced parts of the stock hood? |
#14 | |
| TrackSpec Hood Louvers | CounterSpace Garage | Forced Induction | 75 | 02-21-2017 08:09 PM |
| LOUVERS? | AG3NT_5CARFAC3 | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 01-25-2017 06:55 PM |
| WTB TRD REAR LOUVERS | 86_dion | Want-To-Buy Requests | 13 | 05-27-2015 05:12 PM |
| knockoff louvers? | cjsporl1996 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-21-2014 01:09 AM |
