Old 07-06-2016, 08:18 PM   #1
Italian
Drives: 2013 FR-S Hot Lava
Is my ECU flashed?
Hello all!
I just picked up a 2013 FR-S. I noticed that the precious owner put on a invidia exhaust on. So I got to thinking, what else did he/she do? My next thought was ECU....which brings me here....how the hell can I tell if it's been flashed?
Thanks!
Italian is offline   Reply With Quote
Old 07-07-2016, 03:54 AM   #2
swarb
Get something to pull the tune, either open flash tuner or tatrix cable and then compare it to a stock tune. Or maybe it will just be labeled differently.
Old 07-07-2016, 04:50 AM   #3
steve99
Its not easy to determine if tune is stock, unless you have access to a device to read roms or at least read the cvn (checksum) value then compare it to a stock rom of same calibration id
Old 07-07-2016, 05:31 AM   #4
FingerDiddle
Drives: Camry 08
Take it to a dealer and ask them politely if they could check it for $20
FingerDiddle is offline   Reply With Quote
Old 07-07-2016, 06:16 AM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Interesting conundrum, if you go to the dealer and he finds that the car has had a tweak will this influence any future issues with warranties?
Old 07-07-2016, 08:27 AM   #6
FingerDiddle
Drives: Camry 08
In Australia it's a 3 year warranty, if it's the same where you are I doubt you need to worry.
Old 07-07-2016, 08:39 AM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
5 years or 100k miles whichever comes sooner.
Old 07-07-2016, 08:50 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
5 years
Old 07-07-2016, 03:30 PM   #9
ryoma
ryoma's Avatar
can you ask the previous owner if he had a tune on a car? if you can't contact him and don't have a way to pull the tune off the ECU, then with the car on and stopped, pull the cruise control stalk and see if the RPM needle jumps up to 1, 2, or 3, etc to see if you have an EcuTek tune. I am not exactly sure how to change maps since I don't have EcuTek, but it's something like that (you can find out more with a forum search). then if nothing happens, just clutch in and floor it to see if you have launch control. if it just revs to redline, and map changing doesn't work, then you probably don't have a tune.
Old 07-07-2016, 05:50 PM   #10
steve99
Unfortunatly not all ecutek tunes use map switching and launch autoblip and flat foot shift are options. map switching can also be done via defrost switch or the centre console traction buttons.
It could have also been tuned with brzedit ot an openflash tablet or tactrix ecuflash, which dont have those features
Old 07-07-2016, 10:17 PM   #11
Italian
Thanks.
Now...to find someone with all that. Ha
I've never read data from a ECU before.
Old 07-07-2016, 10:24 PM   #12
Italian
Thanks guys, I'll try that all later.
And also, I've been seeing "flat foot shift"..is that literally you can leave the gas peddle slammed and still shift?
Old 07-07-2016, 10:28 PM   #13
Italian
Also, is there any flashes out there that can put your car into a antitheft mode? I use to have a 05 GLI jetta, the APR flash had that, once on, there was no way of getting the car started unless you knew the password through a series of actions performed through the cruise control buttons. .....I just would hate to start to push buttons seeing of my FR-S had a flasg and push the wrong sequence and lock the car up ha.
Old 07-08-2016, 12:16 AM   #14
steve99
If your car is running fine dont worry, only a small percentage of cars are tuned, if the header is still stock then it unlikely (and you cannot see evidence of work ie removal replacement of parts like intake or headers) then it unlikly it tuned.
The standard security key fob is very good theirs no need to add additional security.
you can get ecutek tunes with a valet mode where car will run but at reduced power and rpm limit inless you know how to switch maps, i dont think they have the coded sequence for frs\brz. unfortunatly a lot of people know how to map switch on ecutek.
yes flat foot shift you can chage gear in manual at 100% throttle, you still use clutch, and it signals ecu to cut power as you shift, can do it with ecutek and oft and brzedit tunes, the ecutek has a better system though
Dealer flashed ecu now cel and tcs unscannable Norinradd Issues | Warranty | Recalls / TSB 23 06-15-2016 06:44 PM
Just flashed OFT Stage 2 UEL Luftwaffel Software Tuning 14 11-30-2015 09:33 PM
Just flashed 2015 FRS with OFT Flat_4_Life Software Tuning 4 03-23-2015 09:22 PM
Flashed ECU Djen Software Tuning 5 08-13-2013 09:00 AM
What car is flashed in the Mazda 3 commercial Yruyur Other Vehicles & General Automotive Discussions 10 03-29-2013 12:23 PM
