Old 08-13-2013, 06:57 AM   #1
Djen
Drives: GT86
Flashed ECU
hi ther. if the car now have flashed ecu. the computer no longer controlled by the car ecu? I mean I just done tuning the car and duno if this goin be gone I have losing power some high AFRS this will be controlled by ecu itself and cure it sometimes?
Djen is offline   Reply With Quote
Old 08-13-2013, 07:54 AM   #2
Foobar
SLO NO MO
Foobar's Avatar
Have your tuner check your logs. Shouldn't have AFRs out of spec.
Sent from my Nexus 4 using Tapatalk 2
Old 08-13-2013, 08:05 AM   #3
Djen
Drives: GT86
well I sent logs im waiting for respone.. anyways I ve heard reseting ecu there is some couple handred miles driving to let the ecu understanding and learning. is this for stock oem ecu or same for ecutek flashed car?
Old 08-13-2013, 08:15 AM   #4
mad_sb
Drives: 2013 Asphalt FR-S
what is changed with the reflash is the table data inside the ECU, NOT the ecu code itself for the most part. It functions just like the stock ecu with different targets for fuel, timing, cam angle, etc etc.
There will be a "learning" period with either stock or reflashed, but it does not take serveral hundred miles. Just one or two 20 minute drives is all it should take for throttle plate position, IAM, and long term fuel trims to settle in.
Old 08-13-2013, 08:21 AM   #5
Djen
Drives: GT86
damn, so what about A/F Learn Value and Knock Correction Learn been doing ?? I was loged in live data and keep tracking those
Old 08-13-2013, 09:00 AM   #6
mad_sb
A/F learn value is what i referred too as Long Term Fuel Trim
Knock Correction = IAM
They will continuously change but after a drive cycle or two they should be in the range they will likely stay in.
What car is flashed in the Mazda 3 commercial Yruyur Other Vehicles & General Automotive Discussions 10 03-29-2013 12:23 PM
