Old 03-23-2015, 08:26 PM   #1
Flat_4_Life
Flat_4_Life's Avatar
Drives: 2015 SBD Turbo Halo FRS
Exclamation Just flashed 2015 FRS with OFT
Hey everyone,
just flashed my 2015 FRS with OFT stage 1 91oct tune. hard to say if i can notice a real difference or not but still early. i did notice near the end of my drive after flashing that the low end torque seemed better and felt like it had more pull in the higher gears at lower RPMs. does anybody know if the tune i have has Flat foot shifting and launch control? if i do how do i set it up or if i dont how can i get it?
Flat_4_Life is offline   Reply With Quote
Old 03-23-2015, 08:29 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Flat_4_Life View Post
Hey everyone,
After your flash your ECU (or disconnect the battery) you will have to drive around for a few drive cycles until your throttle calibrations. Until then you will feel a little dead spot at the beginning of the pedal travel. With the OTS maps you will indeed feel some pretty obvious gains in the usual torque dip area (2500-3500rpm). And at very high RPM (above 6500rpm). As for FFS/LC, I would need to know what your Calibration ID is. You can view this (called Calibration Code) in the ECU info section on your OFT.
Cheers,
shiv
Old 03-23-2015, 08:34 PM   #3
Flat_4_Life
Cheers,
shiv
sorry for my stupidity but what are OTS maps? and my calibration ID is ZA1JD00C
Old 03-23-2015, 08:35 PM   #4
_gt86_user
Inactive
Drives: .
Cheers,
shiv
I have the same question, I have the d00c calid I know you guys were working on it for the 2015's, any ETA? Thanks!
_gt86_user is offline   Reply With Quote
Old 03-23-2015, 09:22 PM   #5
Burrcold
Drives: Subaru BRZ Limited
Off The Shelf
Just flashed OFT Stage 2 UEL E85 tune. How long should I wait before logging? momo3605 Software Tuning 7 02-21-2015 07:32 AM
Anyone one flashed back and had a problem at the dealer? (chirp chirp chirp) OkieSnuffBox Software Tuning 16 11-18-2014 04:56 PM
Openflash Tablet Only Flashed on car ONCE! SOLD Vlady Engine, Exhaust, Bolt-Ons 4 09-01-2014 03:44 AM
Flashed ECU Djen Software Tuning 5 08-13-2013 09:00 AM
What car is flashed in the Mazda 3 commercial Yruyur Other Vehicles & General Automotive Discussions 10 03-29-2013 12:23 PM
