tach starts below 0
Long story short, the plastic shield that protects the gague cluster isn't in the car and my buddys kid, who is 2, while sitting in the car just enjoying the car messed up the cluster and broke it/ moved the nedle. When I start the car, the whole rpm range is about 4k low(on the tach). Is there any way to get it back to the way it sould be? would a flash of the tune fix it?
move the needle back? lol. lift it off and put it back on
Let the 2 year old fix it. He broke it!
Drives: 2013 satin white brz limited
Flash and tune will not fix it. Its Likely the mechanical's are damaged.
Drives: 2016 ZC6
^^^ This. Go check out LED swaps for the cluster or cluster dial swaps for how to do it.
My build thread: Pointmutation's WRB BRZ build
Drives: 2016 Cosworth 2.2 BRZ
Turn it back the other way until it settles on 0. The needle slipped one way, it might slip the other way.
Drives: Subaru BRZ
You can always add it to list of other redundant features that appear on our dashboards..
#10 |
Drives: Subaru BRZ
#11 |
#12 |
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Just leave it. At idle, you will actually be producing gas. But please do not shift at indicated redline.
#13 |
Drives: Subaru BRZ
#14 |
| HELP: Need Tach Signal!! | Lil Abner | Electronics | Audio | NAV | Infotainment | 39 | 02-24-2016 08:59 PM |
| LS Swap Tach Pickup Kit | Cross | Engine, Exhaust, Bolt-Ons | 2 | 09-09-2015 08:30 PM |
| Cant see the top of my tach... | MadFRS | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-29-2013 04:11 PM |
| BRZ tach to FRS? | lavisxice | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-01-2013 03:48 PM |
| Tach sweep is gone | whtchocla7e | Issues | Warranty | Recalls / TSB | 14 | 01-30-2013 10:07 PM |
