Old 06-28-2016, 08:54 PM   #1
aquaman
aquaman's Avatar
tach starts below 0
Long story short, the plastic shield that protects the gague cluster isn't in the car and my buddys kid, who is 2, while sitting in the car just enjoying the car messed up the cluster and broke it/ moved the nedle. When I start the car, the whole rpm range is about 4k low(on the tach). Is there any way to get it back to the way it sould be? would a flash of the tune fix it?
aquaman is offline   Reply With Quote
Old 06-28-2016, 11:08 PM   #2
ryoma
ryoma's Avatar
move the needle back? lol. lift it off and put it back on
Old 06-29-2016, 09:26 AM   #3
Let the 2 year old fix it. He broke it!
FX86 (06-29-2016), JD001 (06-29-2016)
Old 06-29-2016, 09:29 AM   #4
jasonojordan
Drives: 2013 satin white brz limited
Flash and tune will not fix it. Its Likely the mechanical's are damaged.
jasonojordan is offline   Reply With Quote
Old 06-29-2016, 04:30 PM   #5
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
^^^ This. Go check out LED swaps for the cluster or cluster dial swaps for how to do it.
Pointmutation is offline   Reply With Quote
Old 06-30-2016, 02:56 PM   #6
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Turn it back the other way until it settles on 0. The needle slipped one way, it might slip the other way.
sly is offline   Reply With Quote
Old 07-01-2016, 08:11 AM   #7
aquaman
aquaman's Avatar
thanks for the idea, i'll give it a shot
Old 07-01-2016, 08:37 AM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
You can always add it to list of other redundant features that appear on our dashboards..
Old 07-01-2016, 08:41 AM   #9
jasonojordan
Where is there a redundant tach?
Old 07-01-2016, 08:53 AM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Not quite but we do have a redundant speedometer.
Old 07-01-2016, 10:03 AM   #11
jasonojordan
Yes but this is a thread about issues with his tach not his speedo. So yea point of your comment?
Old 07-01-2016, 10:21 AM   #12
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Just leave it. At idle, you will actually be producing gas. But please do not shift at indicated redline.
geezerbrzeezer is offline   Reply With Quote
The Following 2 Users Say Thank You to geezerbrzeezer For This Useful Post:
JD001 (07-01-2016), Tcoat (07-01-2016)
Old 07-01-2016, 10:32 AM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
As per the above response.
Old 07-01-2016, 10:46 AM   #14
jasonojordan
I see nothing at all referencing issues with the speedo on any of the comments or the OP. Other they you just throwing out we have a redundant speedo (We all know this...)
HELP: Need Tach Signal!! Lil Abner Electronics | Audio | NAV | Infotainment 39 02-24-2016 08:59 PM
LS Swap Tach Pickup Kit Cross Engine, Exhaust, Bolt-Ons 2 09-09-2015 08:30 PM
Cant see the top of my tach... MadFRS Scion FR-S / Toyota 86 GT86 General Forum 31 07-29-2013 04:11 PM
BRZ tach to FRS? lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-01-2013 03:48 PM
Tach sweep is gone whtchocla7e Issues | Warranty | Recalls / TSB 14 01-30-2013 10:07 PM
