Drives: 2013 FR-S, 6MT, Ultramarine
Does anyone know where I can get a tach signal inside the car? I would rather not grab a signal off the engine. There has to be a signal at the Body ECU, but my o-scope is broke so I can't find it.
Any help is appreciated!! |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
There isn't one.
Sorry. Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
I don't believe that. There has to be a tach signal for the OEM tachometer in the gauge cluster. Unless it's in a data stream from the engine bay...
Drives: Whiteout 6MT FR-S; E30 BMW's
Here you go: http://www.ft86club.com/forums/showthread.php?t=10292
Should be able to follow that to its termination, however it very well may terminate in the engine bay into a control module, and not go all the way to the ECU in the cabin. |
Hmm. Thanks, but still not helping. I'm hoping someone knows what pin on the Body ECU under the dash is the tach signal. I hate splicing into wires in the engine bay.
The tach signal is communicated between the Engine ECU and Gauge Cluster, etc. on the CAN BUS. There is no single wire for tach, it is a data stream.
I didn't just guess before I posted, I looked it up first. Jeff
#7 | |
![]() Ok, thanks. I guess I'll do some solder/heat shrink under the hood... |
Why do you not want to grab the tach signal in the engine bay? With a little spray silicone you should be able to run the wire through an existing hole in a grommet.
#9 | |
The schematic I'm using shows 4 tach signals on the passenger side large connector. So I'm going to try those. |
#10 |
Drives: FRS with 2jz, 2015 STI 9.68@147
If theres a red/black at the obd 2 connector you can get tach there.
#11 | |
Oh yeah, I forgot winter even existed. We have a few months out of the year that require a hoody and jeans but that's it.
#12 |
Looking into it further, it looks like the ECU has a dedicated "TACH" output signal, pin A35-15 on the ECU. This is the 35-pin connector.
It probably heads over to the DLC2 connector or something, because it isn't heading to any other systems in any of the wiring diagrams which is where I initially checked. Every other ECU, etc. uses the CAN-BUS to get the tach signal, but as I said there is an output dedicated to it on the ECU. It's not shown in any wiring diagrams, but it is mentioned in the RM. Nice of them to do that. Jeff
#13 |
Drives: 2013 BRZ Limited
subscribed.
#14 |
Drives: Argento 6spd FR-S
subd as well... if jeff lange is on top of this research it will be no time at all till a definitive answer. Guy knows his shit.
| BRZ NAV system GPS signal issues? | DigDloppyFonkeyBick | Electronics | Audio | NAV | Infotainment | 73 | 06-07-2016 02:14 AM |
| Turn Signal Repeaters | Ben_G | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-22-2012 10:26 PM |
| BRZ signal light bulb | ubersoph | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-20-2012 01:26 AM |
| Scion FR-S Tach Sweep Video | F1point4 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 06-15-2012 03:53 PM |
| plastic in front of tach | feldy | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-10-2012 12:03 AM |
