Drives: 13 FR-S whiteout / blue w2w
ECUtek data logging problems
I have been trying to do in car logging ( track only not street legal) with ECUTEK. Every time, the logging to file stops after a few minutes or sometimes seconds, so I am never able to capture anything with WOT.
The error I get that no signal is received. When I disconnect everything, wait a few minutes, repeat it all over again, I get the same results, it logs for up to a few minutes and then stops. I have tried different cables, but I have no problem logging an AIM solo. I did have a problem with the AIM solo once, but that was results when I extended the OBD cable. Since then I have never had a problem with the AIM Solo. Does anyone have any suggestions how to get this fixed ? The car is a 2013 FR-S |
Drives: UK GT86
Is ECUtek updated?
The main culprits are USB connection or OBD connection. However it could be the cable itself, which I believe someone had a faulty one. Are you using an in car laptop charger? Seen that cause odd issues if a loose 12v socket connection.
.: Stealth 86 :.
ECUtek was updated the same day as the logging. Using a tablet so no use of in car power, but am using a USB hub dongle. I guess I will have to try with a regular tablet that has 2 USB ports.
Try reducing the number of logged parameters
| Can you run ecutek data logging on a samsung windows tablet | Frs32907 | Software Tuning | 10 | 02-09-2016 10:30 PM |
| best data logging options | canadaRS1.0 | Software Tuning | 2 | 04-21-2015 05:25 PM |
| school me on data logging | fatoni | Tracking / Autocross / HPDE / Drifting | 11 | 01-09-2014 09:54 PM |
| Ecutek Deltadash data logging advanced functions | Yruyur | Software Tuning | 8 | 08-20-2013 01:10 PM |
| Ecutek Map Access, data logging Vs. obd2 sensor | lbroskee | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 01-06-2013 02:56 PM |
