Old 05-20-2016, 05:55 PM   #1
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Need a new engine...
Well, I spun a bearing and now I'll need a new engine. I found a used engine in Fontana for 2500. I'll probably get that and put it in this weekend.
Then it will be time to start rebuilding the engine with the spun bearing with all sorts of good internals... Fun Times...
Didn't want to do this yet but not left with much of a choice...lol...
Jaden
Jaden is offline   Reply With Quote
Old 05-20-2016, 08:04 PM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Details? What tune/modifications are you running? What oil? Dealer service? Service interval? Any racing? Boost?
Also this should probably go in the issues section.
Decay107 is offline   Reply With Quote
Old 05-20-2016, 09:58 PM   #3
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
You're not going to do much better than $2500 for a (non blown) long block.
Good luck with the rebuild.
Bigger valves.
Just sayin'
Edit: I already feel bad for typing that.
Unrelated curiosity... What turbo were you running anyway?
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 05-20-2016, 10:40 PM   #4
stevesnj
stevesnj's Avatar
An epidemic it sounds like. I know someone with a 2013. Hope it doesn't happen to his.
My 2016 Build thread
Old 05-20-2016, 11:38 PM   #5
Jaden
Road-hole
no boost
I was running an oft stage 1 on 91 at the time. I regularly changed/checked the oil. Most of the 75K I put on it was on E85.
I've driven the shit out of it though. Put a harsh 75K on it in two years. It was running motul ow20.
It went right after a pull at 126mph...
Jaden
Old 05-21-2016, 12:16 AM   #6
humfrz
Me too ....... with my 2013.
Of course, I don't hammer on mine, like it sounds like @Jaden did his .....
@Jaden, sorry to hear about your machine coming apart .....
humfrz
Old 05-21-2016, 12:45 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Too soon?
Seriously though, bummer, @Jaden. You'll make the best of it. Keep us posted.
Old 05-21-2016, 01:40 AM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Jaden
Did the car ever experiance overreving from misshifts or lots of time at the rev limiter?
Old 05-21-2016, 12:40 PM   #9
USMCgetsome
Drives: stock 2013 fr-s
questions are.... What kinda tune and did they update for that ecu reflash for the AVCS oil issue where the cams either slip or dont adjust properly.
Also, where are you sourcing your block from? I'm looking for some locally and have only found one. The other source i have is from lkq
USMCgetsome is offline   Reply With Quote
Old 05-22-2016, 12:47 AM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
did you recently switch to 0w20?
Old 05-25-2016, 08:34 PM   #11
Jaden
Road-hole
new engine is in...
Got the new engine in, runs perfect... Now it's time to break down the old engine and see how extensive the damage is.
Correction, I had last put 5w20 Motul in it...not 0w20...
Jaden
Old 05-26-2016, 11:01 PM   #12
USMCgetsome
I did the same only because I was already getting a light tapping and I live in tx. It's already getting hot here.
Old 05-27-2016, 03:40 AM   #13
sqd
sqd's Avatar
Drives: '13 SWP GT86
I just started going down the rabbit hole after reading two threads about 2013 models having leaks. Now of course mine will have a leak as soon as I check. Motherfu-....
And naturally, my warranty runs out in.. four days.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 05-27-2016, 11:25 AM   #14
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
My '13 also failed at ~125mph... but that was 470whp.
If you can, find a '14 motor. They're the newest that'll work on our '13's as a drop-in replacement. You'll get all the internal improvements using a '14 motor versus a pull out of a '13 car.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
FS: Password JDM Engine Covers and Gunmetal Engine Dress Up kit PrimeMotoring Engine, Exhaust, Bolt-Ons 10 11-25-2014 11:38 PM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 08:12 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
