Old 06-24-2014, 09:09 PM   #1
djdrugga24
Drives: Asphalt 2013 Scion FR-S
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms?
I bought my 2013 Automatic Scion FR-S in September of 2013. I drive to and from work, and on the weekends. Mostly local roads with small amounts of time highway. When I was leaving work, I remote started the car and let it ran for 12 minutes before the engine cuts off. I let it sit for about 8 minutes before I entered my car to leave work. I noticed on the dash that the check engine light came on. As I left work, I noticed that the throttle response was weird. Engine wasn't reving as hard as it normally does when I press the gas to a certain point. Once I got onto the highway, I floored it and the engine stalled at 4000 rpm. I tried slowly pressing on the gas and building up the revs and as soon as it hits 4000 rpm, it stalled.
Anyone have any insight?
djdrugga24 is offline   Reply With Quote
Old 06-24-2014, 10:30 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Take it to the dealer. That's pretty much all you can do. Your car is in what's known as "limp mode." Basically it will get you where you need to go, but just barely and it won't do it for long before something fails.
Bobblehead is offline   Reply With Quote
Old 06-24-2014, 10:52 PM   #3
cnk
Drives: '13 DGM BRZ Limited
Get the code scanned so you can see what the ECU thinks is wrong.
cnk is offline   Reply With Quote
Old 06-25-2014, 06:06 AM   #4
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Limping and stalling sounds like a camshaft problem. There's a TSB for that if you got that.
Bach415 is offline   Reply With Quote
Check engine light just came on after 2k miles. danthedirt Issues | Warranty | Recalls / TSB 604 01-31-2015 04:26 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
Check engine light now on at 2995 miles Marshman Issues | Warranty | Recalls / TSB 2 12-17-2012 07:41 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
