| Southern California SoCal |
Drives: 2014 Rocket Bunny Scion FR-S
Sluggish start
Recently my car has been having very sluggish starts, every time I start it starts like if the battery is dead, so I think it might be the battery but here's a little background, it all started happening after one night I left the dome light on all night and came to find my car the next morning completely dead, that same day I took my battery to autozone to get it checked out and they recharged it and told me it was a bad battery(have only had car for 2 years), a coupe of days later I took it to toyota dealer and told them the problem I was having and they took the car in told me the battery was good and everything else checked out good, they recharged it also, it was good for a couple of days but it's giving the same problem the sluggish start, does anyone else have this problem, I don't want to go buy a new battery if the battery isn't the problem, anyone with any comments or like the help, it would be appreciated it -Thank You
Drives: FRS
Most likely its your battery. What happens probably when u drove to dealer it recharged, cuz every time u drive the car it charges battery, but if battery is drained like there's little juice it will die if car is not ran. Borrow another battery from a friend or just replace it 2 years is about life of OEM battery anyways
Sent from my SM-N910T using Tapatalk |
Killed Scion
Drives: 2013 FR-S Whiteout
^ agreed with the above poster.. It is most definitely your battery.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
Amazing Member
Drives: 2014 Whiteout FR-S
Me three! I would say battery also. Everything you've mentioned points to the battery.
BAE
Drives: Asphalt FRS
Or alternator..? Points to battery but check other sources too. Autozone always tells me i have a bad battery when i ask them to test and so i stopped trusting them. How many miles do you have? Do you run big subs or anything that might drain excessive power?
No I don't have any subs or anything electrical that might drain power
Drives: Scion FRS || Ducati 899
if you have the app torque or/and an obd reader you could just watch the voltage when you start up the car
vs once you drive it around for a while
not playing cards
Have you checked the electrolyte level in the cells? You might get lucky. Add only distilled water as required.
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
the stock subaru/panasonic battery is crap always had staring issues took it to dealer, did a load test good charge low cranking amps, gave me a toyota battery starts like a dream
#10 |
Drives: 2013 WRB Subaru BRZ Limited 6MT
If the car is still starting then its probably just a near dead battery. As someone suggested try borrowing a battery with the same CCA and swap it out with your old battery to see if your car still cranks slow. Unless you have access to a voltmeter.
| Car feels sluggish after new Intake + Exhaust | rickygt86 | Engine, Exhaust, Transmission | 17 | 12-24-2015 09:23 PM |
| Feels sluggish after clutch pedal adjustment | brianhj | Engine, Exhaust, Transmission | 6 | 08-24-2013 12:58 PM |
| frs sluggish in first and second gear at 2k-4k rpm | M&W_FRS | Issues | Warranty | Recalls / TSB | 3 | 06-23-2013 03:09 PM |
| Sluggish/Stalling After aFe Intake Install | FR-S Matt | Engine, Exhaust, Transmission | 6 | 01-15-2013 08:57 PM |
| So... is it sluggish? | Surge101 | BRZ First-Gen (2012+) — General Topics | 62 | 06-04-2012 05:30 PM |
