Old 01-15-2013, 09:10 AM   #1
FR-S Matt
Sluggish/Stalling After aFe Intake Install
Installed my aFe Takeda intake last night, had the battery disconnected the whole time. When I finished, I let it run for about 5-10 minutes then turned it off.
This morning, it was light raining. My lower end power seemed like it took more gas to jump up the RPM's. After leaving the highway when I got closer to work... I got completely bogged it felt like. Around 2k rpm I had no power and then randomly the car would jump, and the rpm needle was bouncing a little.
Do you think I have a loose connection or the MAF sensor needs to be checked? Did I not let it run long enough after the install? Just thinking through what it could be. Any ideas from anyone who has the aFe Takeda installed or experienced this, let me know what I should check. Thanks!
Old 01-15-2013, 09:14 AM   #2
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Reset the ECU again, and drive it afterwards, also double check all connections, and make sure there is no loose vacuum hoses. Double check that little hose on the right before the throttle body.
FT-86 SpeedFactory is offline   Reply With Quote
Old 01-15-2013, 11:38 AM   #3
whataboutbob
AutoX-10/10ths every run
I'd check to make sure everything is connected and tight. I didn't reset my ECU after installing mine and it seems to be working fine.
Build thread:Here
Old 01-15-2013, 12:53 PM   #4
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Sounds like a vacuum leak to me. check all connections as previously stated.
Ranatsu is offline   Reply With Quote
Old 01-15-2013, 01:39 PM   #5
FR-S Matt
Thanks guys, hopefully I get home from work in one piece. I'll check what I can with bare hands. Last I looked the MAF was secure, and the hose on the side as well. I will double check them again, and check everything again when I get home along with resetting the ECU. Appreciate the help!
Old 01-15-2013, 03:42 PM   #6
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
after you reset the ECU (taking off the negative line from the battery) turn the ignition and let it idle for 10 mins WITHOUT PUSHING THE ACCELERATOR. It will be like that for the first 50-100miles. It'll improve the more miles you put on it. Happened to me too. Like the statements above, double check all connections make sure nice and tight.
tintumz22 is offline   Reply With Quote
Old 01-15-2013, 08:57 PM   #7
FR-S Matt
Problem is fixed! I retightened everything when I got home. Made sure there were no leaks on any piece, from the filter, to the throttle body. The crank hose is in snug, and the MAF is fine. I had the negative terminal unplugged for 20 minutes roughly. Plugged it back in and let the car idle for 15 minutes, then went for a drive.
Car is running great and I feel the power gains already. Does feel a bit different on take offs but I feel the power when hitting the gas.
Thanks Jeremy and the rest of you guys for all the input. Absolutely loving the Intake now!
Airaid Intake Install with Snorkel Delete DIY W2 DIY (Do-It-Yourself) Guides 28 09-14-2016 05:42 PM
Zeta Performance Intake Review/Install fmsida Engine, Exhaust, Transmission 20 08-15-2013 12:11 PM
AVO Silicone Intake and Sound Tube install and review ESC POD Engine, Exhaust, Transmission 38 05-21-2013 07:18 AM
So... is it sluggish? Surge101 BRZ First-Gen (2012+) — General Topics 62 06-04-2012 05:30 PM
