Old 08-23-2013, 01:55 PM   #1
brianhj
Drives: 2017 Camaro 1SS
Feels sluggish after clutch pedal adjustment
So I adjusted my clutch pedal (lowered it, less travel) last night and it's about even with my brake pedal, if not a LITTLE lower. Also getting the fuel pump chirp (I'm at 700 mi)
My car feels sluggish today, like it's draggin ass. It's not speeding up as fast as it normally does (even though I'm revving it) and when I let off the gas it immediately pulls back and slows down, instead of coasting.
Do either of those two things have anything to do with it? Am I imagining things? I don't think it felt like this before.
brianhj is offline   Reply With Quote
Old 08-23-2013, 02:10 PM   #2
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
Neither of those should affect that. The clutch adjustment.. if adjusted too far down just means you can't enough travel to completely separate the clutch from the flywheel, resulting in grinding when trying to switch gears quickly. Where you set it at is a good spot though, I haven't heard anyone having issues with that placement.
The fuel chirp is annoying, but only a result of using gas with ethanol in it. No performance or reliability issues here.
This car is geared such that if you release the gas while in gear still, you will decelerate fairly quickly. 5th gear is the 1:1 gear, so 1-4 will still slow you down well while "coasting".
As for why the car is feeling slow today... idk
malave7567 is offline   Reply With Quote
Old 08-23-2013, 02:12 PM   #3
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Try setting your FM2 selections to mostly talk radio, should improve your 0-60.
SloS14 is offline   Reply With Quote
The Following User Says Thank You to SloS14 For This Useful Post:
Anthony (08-24-2013)
Old 08-23-2013, 02:27 PM   #4
brianhj
May be my imagination then!
Hahahaha
Old 08-24-2013, 07:40 AM   #5
mad_sb
Drives: 2013 Asphalt FR-S
make sure you adjusted the clutch switch when you did the pedal adjustment. There is a clutch down timing retard table in the ecu (but it only applies as you let the clutch out on a shift, not all the time the pedal is down), if you are no longer closing the switch when the pedal is at the top of travel (foot off the pedal position) the ecu thinks you have the pedal depressed all the time. There may be other compensations active when the ecu thinks the clutch pedal is depressed.
An easy test is to see if you cruise control works, if not, you need to adjust the switch position.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
jcw99 (11-25-2015), Sportsguy83 (08-24-2013)
Old 08-24-2013, 07:45 AM   #6
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
SCIENCE!!
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-24-2013, 12:58 PM   #7
brianhj
Yeah cruise control works.
That's the part I didn't get about the clutch pedal adjustment walkthrough. When I adjust the two nuts the little switch moves with the whole assembly. And when the pedal is released, there's no way for it to not fully depress that switch. So I didn't see how to even adjust the switch.
Gas Pedal Adjustment ML Cosmetic Modification (Interior/Exterior/Lighting) 32 05-01-2017 09:26 PM
Clutch Adjustment Issues!! FT-86- Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2015 09:29 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Every other frs driver thinks my clutch feels different Yruyur Scion FR-S / Toyota 86 GT86 General Forum 4 11-15-2012 09:12 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
