Southern California SoCal
Old 04-25-2016, 05:08 PM   #1
diegoei
diegoei's Avatar
Drives: 2014 Rocket Bunny Scion FR-S
Sluggish start
Recently my car has been having very sluggish starts, every time I start it starts like if the battery is dead, so I think it might be the battery but here's a little background, it all started happening after one night I left the dome light on all night and came to find my car the next morning completely dead, that same day I took my battery to autozone to get it checked out and they recharged it and told me it was a bad battery(have only had car for 2 years), a coupe of days later I took it to toyota dealer and told them the problem I was having and they took the car in told me the battery was good and everything else checked out good, they recharged it also, it was good for a couple of days but it's giving the same problem the sluggish start, does anyone else have this problem, I don't want to go buy a new battery if the battery isn't the problem, anyone with any comments or like the help, it would be appreciated it -Thank You
diegoei is offline   Reply With Quote
Old 04-25-2016, 05:14 PM   #2
Binary_fission
Binary_fission's Avatar
Drives: FRS
Most likely its your battery. What happens probably when u drove to dealer it recharged, cuz every time u drive the car it charges battery, but if battery is drained like there's little juice it will die if car is not ran. Borrow another battery from a friend or just replace it 2 years is about life of OEM battery anyways
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Old 04-25-2016, 05:26 PM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
^ agreed with the above poster.. It is most definitely your battery.
Instagram: trevor.parque
Old 04-25-2016, 05:39 PM   #4
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
Me three! I would say battery also. Everything you've mentioned points to the battery.
MY 86 BUILD
[YOYO] is offline   Reply With Quote
Old 04-25-2016, 09:33 PM   #5
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Or alternator..? Points to battery but check other sources too. Autozone always tells me i have a bad battery when i ask them to test and so i stopped trusting them. How many miles do you have? Do you run big subs or anything that might drain excessive power?
Decimus is offline   Reply With Quote
Old 04-25-2016, 10:13 PM   #6
diegoei
diegoei's Avatar
No I don't have any subs or anything electrical that might drain power
Old 04-25-2016, 11:15 PM   #7
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
if you have the app torque or/and an obd reader you could just watch the voltage when you start up the car vs once you drive it around for a while
Votlon is offline   Reply With Quote
Old 04-25-2016, 11:39 PM   #8
Have you checked the electrolyte level in the cells? You might get lucky. Add only distilled water as required.
Old 04-26-2016, 03:14 AM   #9
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
the stock subaru/panasonic battery is crap always had staring issues took it to dealer, did a load test good charge low cranking amps, gave me a toyota battery starts like a dream
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 04-26-2016, 10:02 AM   #10
gianniBRAVO
gianniBRAVO's Avatar
Drives: 2013 WRB Subaru BRZ Limited 6MT
If the car is still starting then its probably just a near dead battery. As someone suggested try borrowing a battery with the same CCA and swap it out with your old battery to see if your car still cranks slow. Unless you have access to a voltmeter.
gianniBRAVO is offline   Reply With Quote
Car feels sluggish after new Intake + Exhaust rickygt86 Engine, Exhaust, Transmission 17 12-24-2015 09:23 PM
Feels sluggish after clutch pedal adjustment brianhj Engine, Exhaust, Transmission 6 08-24-2013 12:58 PM
frs sluggish in first and second gear at 2k-4k rpm M&W_FRS Issues | Warranty | Recalls / TSB 3 06-23-2013 03:09 PM
Sluggish/Stalling After aFe Intake Install FR-S Matt Engine, Exhaust, Transmission 6 01-15-2013 08:57 PM
So... is it sluggish? Surge101 BRZ First-Gen (2012+) — General Topics 62 06-04-2012 05:30 PM
