Old 04-13-2016, 10:30 PM   #1
zuko
Drives: 2014 Limited WRB BRZ
Rear Deck Rattle
x/posted from https://www.reddit.com/r/ft86/commen...r_deck_rattle/
Hey everyone,
New to this community but _really_ hoping somebody can help me out with a long running issue. I have this incredibly annoying rattle coming from what sounds like my rear deck, it's been going on for quite a while and my attempts to take it to multiple dealers have been beyond unsuccessful. Below are a couple of videos demonstrating the problem.
[ame="https://www.youtube.com/watch?v=2Gl7OEztQ6U"]BRZ Rear Deck Rattle 1 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=zXypjcnMszk"]BRZ Rear Deck Rattle 2 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=KOPZQ3PdRrI"]BRZ Rear Deck Rattle 3 - YouTube[/ame]
It's a loud "ticking" noise that emanates from what sounds like the rear shelf on the driver's side. I've had a friend lay in the trunk while we drove around and he was pretty sure it was from inside the rear shelf. It seems to occur most frequently over bumps and is present at both low and high speeds, though it comes and goes (but when it happens it's dreadful). Some additional background information:
I have confirmed it is none of the following things:
* Speaker
* License plate (or frame) - have removed both and driven around, sound still occurs
* Plastic (trunk release?) tab in the back of the trunk (it's secured with tape)
* Miscellaneous exposed wiring (it's all been secured and padded)
Additional fixes I've attempted:
* On the FT86 forums somebody suggested bending a certain tab in the trunk (with other users confirming it fixed their issue). This had no effect.
* I have taken The TSB referenced here: (http://www.ft86club.com/forums/showthread.php?t=13451) into the dealer on 3 occasions, and on none of those 3 do I believe they actually even looked at it. It may not be related, but it's the closest thing I've found.
Unfortunately, I am not exactly a _car guy_ and am a bit wary of taking apart the rear deck and (as suggested) "popping" some of the spot welds. Every time I've taken it into the dealer I've received ridiculous explanations (among the worst: "your rear seats weren't latched" -- despite the fact that it is often _worse_ with the seats down) and at this point I've deemed it a waste of my time to continue pursuing dealerships.
I love this car but absolutely cannot stand to drive the thing without the windows down or the radio up any longer. Thanks in advance for your help.
zuko is offline   Reply With Quote
Old 04-13-2016, 11:08 PM   #2
humfrz
You might try taking everything out of the trunk (including under the trunk cover, i.e. the spare tire and all the tools/jack) and see if the rattle goes away.
humfrz
Old 04-13-2016, 11:14 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Welcome and yes it is the rear deck itself along with the thrid brake light housing. Mine does that too but it's worse when you add a sub.
You do need to stuff that rear deck with some foam or something. If you don't want to do it take it to a local audio shop and tell them.
Old 04-14-2016, 08:36 AM   #4
zuko
Thanks guys. Mr.ac, are you referring to doing what's suggested here:
humfrz, will try that as well, thanks.
The Following User Says Thank You to zuko For This Useful Post:
XtremeMaC (04-17-2016)
Old 04-14-2016, 08:58 AM   #5
http://www.ft86club.com/forums/showthread.php?t=44636
http://www.ft86club.com/forums/showthread.php?t=10002
http://www.ft86club.com/forums/showthread.php?t=42065
Dadhawk (04-14-2016), humfrz (04-14-2016), nos145 (04-14-2016), Sigh-on-Rice (04-14-2016), Ultramaroon (04-14-2016), XtremeMaC (04-17-2016)
Old 04-14-2016, 09:26 AM   #6
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
Look for any potential for plastic or metal rattle coming from the trunk after removing the spare tire and tools, and buy some Dyna Mat (or Hush Mat) to fill in any mysterious spaces that you might find.
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
Old 04-14-2016, 02:57 PM   #7
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
tcoat with the search function.
nways. common issue.
nos145 is offline   Reply With Quote
Old 04-14-2016, 03:15 PM   #8
What do you mean "search"? I have all the threads memorized and type out the addresses each time!
hypebrz (04-14-2016), mixtape (06-28-2016), nos145 (04-14-2016)
Old 04-14-2016, 03:37 PM   #9
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
@zuko I had the same sound!!!
Mine ended up being the rear bumper corners shifting and the plastic clips taping back and forth while driving. Worst was on the highway at speed.
My main cause was because I added the rally armour mud flaps which when the wind hit them they would flap and make the bumper clips tap.
I fixed it from moving by simply putting a strip of duct tape along the seam of the bumper in the rear wheel wells so that it wouldnt move horizontally back and forth anymore.
Hope that helps man.
jimmillion is offline   Reply With Quote
Old 04-14-2016, 11:59 PM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Hey everyone,
* Speaker
Try the following:
1) Stuff foam into the rear deck from the trunk. Your Third brake light wire will lead into it.
2) Use White Lithium Spray and spray the crevices of the trunk (under third brake light).
I also have a slight ticking from my rear deck. It's worse when it's cold.
N1rve
Old 04-15-2016, 10:25 PM   #11
BRZnut
Drives: BRZ DGM Limited
I had this sound and at first I thought it was coming from the rear deck area. It wasn't.
Turned out to be from movement of the 2 plastic pieces where the drivers side seat belt comes out over. (over your left shoulder). If you look, you will see a smaller upper piece of plastic (which the belt comes out of) and a larger lower one. Where those two pieces meet up, it was making the sound.
What I did was apply clear latex caulk at the joint line. No more noise.
Old 04-16-2016, 09:16 AM   #12
zuko
N1rve, I just did that the other day but sadly it didn't seem to have any effect. I will try the White Lithium Spray next, though, thanks.
BRZnut, I have that one as well (at least I'm fairly certain they are two separate sounds). Let me give that a shot and see if it accomplishes anything.
Thanks for your help everyone.
Old 04-16-2016, 09:18 AM   #13
zuko
Interesting. So were you experiencing the noise even without the mud flaps? I will check it out, though, really appreciate the tip.
Old 04-16-2016, 05:36 PM   #14
jimmillion
Power Ranger Elite
jimmillion's Avatar
Yeah it still did. Once the bumper became loose, tape was the only fix.
Rear Deck Rattle? Fix it in 30s nzer DIY (Do-It-Yourself) Guides 66 08-21-2022 01:27 PM
Solution Found: Rear Deck Rattle jdubz Issues | Warranty | Recalls / TSB 29 10-13-2019 02:48 PM
Rear Deck Rattle from Sub Install mynameisnick4 Electronics | Audio | NAV | Infotainment 6 07-04-2014 03:23 PM
Rear deck rattle - fix it in 30s nzer AUSTRALIA 0 07-25-2013 04:09 PM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 04:35 PM
