DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Scion FR-S 2013 Raven
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise.
1 : Remove your Rear Deck like this :
http://www.ft86club.com/forums/showthread.php?t=10002 2 : "Crack" each spot weld carefully with a flat screw driver on each side, he probably miss some pictures but take your time and don't forget any spots if you don't want to remove the rear deck twice. You just need to push the screw driver into the crack and twist it carefully and slowly, you are supposed to heard a little cracking and you need to twist until the cracking sound stop. ***Important : When I say "CRACK", it's not crack enough like to break spot weld, but to only crack, you just need to squeeze and turn the screw driver a little bit and slowly. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Not too hard, you don't want to broke your brand new car. 3 : Apply Lithium Grease into each crack. ![]() ![]() ![]() 4 : Clean the extra Grease ![]() ![]() ![]() 5 : Clean your rear Window before replace your rear deck because it's too hard to clean on back of the third brake light. ![]() 6 : Replace your Rear Deck ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now, i never heard any cracking noise from the rear deck anymore.....finally!!! ![]() Enjoy! Mike
o= FR-S =o Last edited by Mikepage; 03-15-2014 at 05:34 PM. |
The Following 12 Users Say Thank You to Mikepage For This Useful Post: | dawnst3ar (03-04-2014), djdnz (10-19-2015), FRSFirestorm (11-26-2013), Guff (10-31-2013), Imperius (03-31-2017), Kimsey47 (07-11-2014), R2RO (10-31-2013), shiumai (03-16-2014), Sigh-on-Rice (11-06-2014), Tor (03-27-2017), voyager2285 (10-30-2013), xxBrun0xx (04-21-2016) |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
You might want to explain "crack each spot weld" a little better, do you mean seprate each spot weld, or bend up the metal to get the grease in there.. Might just want to explain that better before people are prying and prying because they think you mean break each spot weld completely apart.. Unless that's what you mean, and if so I might just live with the noise lol..
Done, i was editing while you reply: P
You just need to "crack" each spot weld until the cracking noise stop.
o= FR-S =o |
Bump
o= FR-S =o |
Drives: WRB BRZ
Wow! And I thought I was hearing things or there are so many rocks hitting the body of my car! Thanks!
No problem :p
o= FR-S =o |
Drives: old
On mine, I had a light tick sound and fixed it by spraying deep creep in the pocket shaped cavities on the underside of the rear deck, no disassembly required. I'd try that before taking everything apart.
I have already try without disassemble and spraying some Lithium grease and the sound never disappeared.
This is why my solution is for others user where only use grease doesn't fix the problem. And this is not only concerning using grease, this is also about, you need to crack each spot weld.
o= FR-S =o Last edited by Mikepage; 11-02-2013 at 10:19 PM. |
Are you 20/20?
Drives: Hopes and dreams
Toi, tu dois etre Quebecois
#10 |
Oui
![]() You mean my English is bad?
o= FR-S =o |
#11 | |
Are you 20/20?
The Following User Says Thank You to AznKirby For This Useful Post: | Mikepage (11-03-2013) |
#12 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
Thanks to the OP for putting this up. I've been able to eleminate 90% of my deck popping by applying this "cracking" of panel joints I can get to witout removing the rear tray. The majority of them being the underside of the deck in the trunk. I'll also add that by dropping the rear seat and grabbing the top portion along the deck and pulling pretty hard "cracked" a few more joints.
Made a big difference but still a minor pop going on. I'm sure I'll nedd to remove the plastic deck at some point to get to the joints underneath it to eleminate it entirely. |
The Following User Says Thank You to FRSFirestorm For This Useful Post: | Mikepage (11-26-2013) |
#13 |
No problem
o= FR-S =o |
#14 |
Drives: 2013 MT FR-S Asphalt
Spent several hours disassembling the car this weekend, put grease all over that back deck, and viola! The problem seems to be fixed! Thank you so much for this write up - my mornings will be much less stressful now.
The Following User Says Thank You to dawnst3ar For This Useful Post: | Mikepage (03-04-2014) |
Rear Deck "popping/clicking/tapping/ticking" noise. | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 637 | 04-28-2020 04:55 AM |
Subaru TSB 12-140-12 for Rear Deck Popping | sparks | Issues | Warranty | Recalls / TSB | 31 | 07-17-2013 11:11 AM |
GTS rear left popping/clicking sound and fix. | sigmaoctantis | AUSTRALIA | 11 | 05-19-2013 06:58 AM |
Ticking/Clicking Noise front - passenger side | PoRco | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 05-06-2013 05:55 PM |
Rear deck popping/clicking | DriftEightSix | AUSTRALIA | 6 | 02-01-2013 01:59 AM |
